The 15.6-inch MB168B portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a 1366 x 768 HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality.
One cable does the job
15.6-inch HD display with a single USB 3.0 cable for power and data transmission. -
Sleek and ultra-portable with a Zen-inspired design
The MB168B is the slim and light companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations. A durable metallic finish with a fine pattern of concentric circles makes the MB168B the perfect complement to your notebook. -
Adjusting to your needs
The M8168B can automatically senses its orientation and switches the display between landscape and portrait based on its position, while backlight brightness is also automatically adjusted based on environmental lighting - getting brighter in the light and dimmer in the dark.
- ASUS MB168B - LED monitor - 15.6"
- LED-backlit LCD monitor - 15.6"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/419763
- Energy Class
- Class F
- Power Consumption (On mode)
- 13 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Brightness
- 200 cd/m²
- Contrast Ratio
- 500:1 (dynamic)
- Response Time
- 11 ms
- Input Connectors
- USB
- Black, silver
- 37.9 cm x 0.8 cm x 23.6 cm
- 800 g
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Brightness
- 200 cd/m²
- Contrast Ratio
- 500:1 (dynamic)
- Response Time
- 11 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- WLED
- ASUS AI Light
- Black, silver
- 800 g
- USB 3.0
- G-sensor
- Included Accessories
- ASUS Smart Case
- Cables Included
- 1 x SuperSpeed USB cable
- 13 W
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 7.5 watt
- 0 watt
- OS Required
- Microsoft Windows 7
- Shipping Width
- 43.5 cm
- Shipping Depth
- 5.7 cm
- Shipping Height
- 29.7 cm
- Shipping Weight
- 2 kg
