M5A99FX PRO R2.0: CPU and DRAM Digital Power Design for a 100% Performance Boost on AMD 990FX Platform
- Dual Intelligent Processors 3 with New DIGI+ Power Control - Full Hardware Control. Total Performance Tuning.
- Remote GO! - One-stop PC Remote Control and Home Entertainment
- USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
- Network iControl - Real-time Network Bandwidth Control
- DirectKey - A Dedicated Button to Access the BIOS Directly
- USB BIOS Flashback - Easy, Worry-free USB BIOS Flashback with Hardware-based Design
- UEFI BIOS - Flexible & Easy BIOS Interface
The world's first dual intelligent processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with DIGI+ power control provides a total CPU, memory and SMART DIGI+ Key profile tuning digital power solution, which includes two digital voltage controllers allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control - a first on the AMD platform. It's upgraded with one-click extreme performance optimization with the user-friendly AI Suite II utility. This evolution of innovative and industry-leading ASUS technology provides super-accurate voltage tuning for better efficiency, stability and performance.
The DIGI+ power control design with two digital voltage controllers upgrades motherboard power delivery to an overall solution on AMD AM3+ motherboards, including all DRAM controllers that offers ultra-precise memory tuning in addition to ultra-precise CPU voltage control. This evolution of innovative, industry-leading ASUS technology provides the best in class control for better efficiency, stability and performance.
ASUS facilitates strategic USB 3.0 accessibility for both the front and rear panel - 4 USB 3.0 ports in total. Experience the latest plug & play connectivity at speeds up to 10 times faster than USB 2.0. This motherboard affords greater convenience to high speed connectivity.
Dual intelligent processors 3 with DIGI+ power control
The world's first dual intelligent processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with DIGI+ power control provides a total CPU, memory and SMART DIGI+ Key profile tuning digital power solution, which includes two digital voltage controllers allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control - a first on the AMD platform. It's upgraded with one-click extreme performance optimization with the user-friendly AI Suite II utility. This evolution of innovative and industry-leading ASUS technology provides super-accurate voltage tuning for better efficiency, stability and performance. -
All digital power control for both CPU and DRAM
The DIGI+ power control design with two digital voltage controllers upgrades motherboard power delivery to an overall solution on AMD AM3+ motherboards, including all DRAM controllers that offers ultra-precise memory tuning in addition to ultra-precise CPU voltage control. This evolution of innovative, industry-leading ASUS technology provides the best in class control for better efficiency, stability and performance. -
TPU with the all SMART DIGI+ key for a blazing performance boost
Always at the forefront of power design, ASUS propels you into the future standard of power management again by giving you a complete CPU, memory and SMART DIGI+ technology with profile tuning digital power solution, which works with the TPU to ramp up performance to its maximum. Enable the all SMART DIGI+ Key profile with a single click and adjust CPU ratios manually in the TPU to increase CPU frequency up to an incredible 100%! -
Increased CPU and DRAM overclocking range
With programmable digital controllers onboard, users can adjust CPU and DRAM voltage and VRM switching frequencies for various overclocking scenarios. DRAM tuning possibilities make the most of DDR3 memory for better performance with CPU/NB load line calibration and 30% more DRAM current capacity. Thanks to a slew of power options teamed with an extensive and intuitive UEFI BIOS, overclocking very large memory setups is no more difficult than mainstream motherboards. -
The Ultimate Turbo Processor (TPU)
Unleash your performance with ASUS AI Suite II utility. The TPU chip offers precise voltage control and advanced monitoring through Auto Tuning and TurboV functions. Auto Tuning offers a user friendly way to automatically optimize the system for fast, yet stable clock speeds, while TurboV enables unlimited freedom to adjust CPU frequencies and ratios for optimized performance in diverse situations. -
Energy efficiency all around
Tap into the world's first real-time PC power saving chip through AI Suite II utility. Get total system-wide energy optimization by automatically detecting current PC loadings and intelligently moderating power consumption. This also reduces fan noise and extends component longevity! -
One-stop PC remote control and home entertainment
Remote GO! links PCs, tablets, smartphones and TVs wirelessly together through an existing LAN cable and router setup. It allows users to stream multimedia content from PC to DLNA devices, access their computer anywhere using their mobile device at home, while also allowing easy file transfers between your computer and mobile device. It provides seamless environment for a futuristic connected lifestyle with three useful functions: DLNA media hub, remote desktop and file transfer. -
Faster USB 3.0 transmission with UASP
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol), the latest USB 3.0 standard. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. -
Easy, worry-free USB BIOS flashback
USB BIOS flashback offers the most convenient way to flash the BIOS ever! It allows overclockers to try UEFI BIOS versions easily, without even entering their existing BIOS or operating system. It even works without key components such as the CPU and memory installed. Just plug in any USB storage and push the dedicated button for 3 seconds. -
A dedicated button to access the BIOS directly
Designed for users requiring frequent BIOS access, you can easily enter the BIOS automatically when the PC is on standby power with a press of a button. It saves you time during boot-up from having to repeatedly press the DEL key. Convenience and ease at its best! -
Real-time network bandwidth control
With a single-click on/off button, the application currently in use has its data and network bandwidth prioritized over other programs. Moreover, you can prioritize your favorite software easily by configuring profiles through the intuitive user interface. Within the profile, programs can be pre-scheduled to run in a specific time period to avoid network congestion and long-waits on downloads. -
Double USB access, double convenience
- ASUS M5A99FX PRO R2.0 - motherboard - ATX - Socket AM3+ - AMD 990FX
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 990FX / AMD SB950
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Athlon II, Phenom II, FX (supports CPUs with up to 8 cores, Maximum TDP 220 Watt)
- Data Bus Transfer Rate
- 5.2 GT/s
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
- Storage Ports
- 5 x SATA-600, 2 x SATA-600, 1 x eSATA-300
- USB / FireWire Ports
- 2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Max Bus Speed
- 2600 MHz
- 5.2 GT/s
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC892
- DTS Connect, High Definition Audio, DTS UltraPC II
LAN
- Network Controller
- Realtek RTL8111F
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
- Storage Interfaces
- AMD SB950: SATA-600 -connectors: 5 x 7pin SATA, 1 x 7pin eSATA - 6 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 8 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 2 x USB 3.0 , 8 x USB 2.0 , 1 x serial , 1 x SPDIF out , 1 x audio
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS MyLogo3, ASUS O.C. Profile, ACPI 2.0a support, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Q-Connector, ASUS Noise Filter, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Precision Tweaker 2, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS TurboV, ASUS 6+2 Phase Power Design, ASUS TPU (TurboV Processing Unit), USB 3.0 Boost, Dual Intelligent Processors 3, Fanless Design Heat-pipe, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Network iControl, ASUS SMART DIGI+, ASUS Remote GO!, DirectKey
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS CPU-Z
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 24.4 cm
Asus M5A99FX PRO R2.0 AM3+ AMD 990FX DDR3 ATX
