Asus M5A78L-M LX3 AM3+ AMD 760G DDR3 uATX
Reduced Price - Whilst Stocks Last
Quicklinx: 83H8WS00 Mfr#: M5A78L-M LX3
M5A78L-M LX3: The most cost-effective solution for the AM3+ platform combined with ASUS EPU
  • AM3+ CPU Support Ready
  • Core Unlocker- Unlock true Core performance intelligently
  • Anti-Surge- Full-time Power Guardian-Make System Free From Risk
  • ASUS EPU- System Level Energy Saving
  • Low EMI- protect you - 50% less radiation
  • EPU-4 engine
    The ASUS EPU - the world's first power saving engine, has been upgraded to a 4-engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. The EPU automatically provides the appropriate power usage for the CPU, VGA card, hard drives and CPU cooler fan - helping save power and money.
  • ASUS anti-surge protection
    Anti-surge protection design detects overvoltage conditions and prevents voltage surges from spreading in real time. It also actively cuts off the overvoltage supply to protect the system.
  • ESD
    Protect your computer with ESD guards. Electrostatic discharge (ESD) conditions can happen while plugging or unplugging any USB peripherals-causing damage to the computer. ASUS ESD guards clamp the ESD voltage and shunt the majority of the ESD current away for a more reliable computing environment.
  • Core Unlocker
    ASUS Core Unlocker simplifies the activation of an AMD CPU - with just a simply key. Enjoy an instant performance boost by simply unlocking the extra cores, without performing complicated BIOS changes.
  • Fan Xpert
    ASUS Fan Xpert intelligently allows you to adjust the CPU and chassis fan speeds according to different ambient temperatures caused by different climate conditions in different geographic regions and your PC's loading. The built-in variety of useful profiles offers flexible controls of fan speed to achieve a quiet and cool environment.
  • 8-channel high definition audio
    Enjoy high-end sound system on your PC! The onboard 8-channel HD audio CODEC enables high-quality 192 KHz/24-bit audio output, jack-sensing feature, retasking functions and multi-streaming technology that simultaneously send different audio streams to different destinations. You can now talk to your partners on the headphone while playing a multi-channel network games. All of these are done on one computer.
ASUS M5A78L-M LX3 - motherboard - micro ATX - Socket AM3+ - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX (Maximum TDP 95 Watt)
Data Bus Transfer Rate
5.2 GT/s
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Graphics
ATI Radeon HD 3000
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Max Bus Speed
2600 MHz
5.2 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon HD 3000
Memory Allocation Technology
Shared Video Memory (UMA)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
AMD SB710: SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x serial , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.7 support
Hardware Features
C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, jack retasking, ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS EPU-4 Engine, Core Unlocker, AMD Hybrid CrossFireX technology support
Software Included
Drivers & Utilities, ASUS PC Probe 2, ASUS AI Charger, ASUS Update
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
18.8 cm
