This motherboard supports AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1333 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process.
The motherboard supports DDR3 memory that features data transfer rates of 1800(O.C.)/1600/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6GB/s. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution.
The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite settings.
The motherboard supports the next-generation hard drives based on the Serial ATA (SATA) 3 Gb/s storage specification, delivering enhanced scalability and doubling the bus bandwidth for high-speed data retrieval and saves. The external SATA port located at the back I/O provides smart setup and hot-plug functions. Easily backup photos, videos and other entertainment contents on external devices.
AMD Phenom II/Athlon II/Sempron 100 series processors (socket AM3)
This motherboard supports AMD Socket AM3 multi-core processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel DDR3 1333 memory support and accelerates data transfer rate up to 5200MT/s via HyperTransport 3.0 based system bus. This motherboard also supports AMD CPUs in the 45nm manufacturing process. -
Dual-channel DDR3 1800(O.C.) support
The motherboard supports DDR3 memory that features data transfer rates of 1800(O.C.)/1600/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 25.6GB/s. Furthermore, the supply voltage for the memory is reduced from 1.8 V for DDR2 to just 1.5 V for DDR3. This voltage reduction limits the power consumption and heat generation of DDR3 which makes it an ideal memory solution. -
ATI CrossFireX technology
ATI's CrossFireX boosts image quality along with rendering speed, eliminating the need to scale down screen resolution to get high quality images. CrossFireX allows higher anti-aliasing, anisotropic filtering, shading, and texture settings. Adjust your display configurations, experiment with the advanced 3D settings, and check the effects with a real-time 3D-rendered preview within ATI Catalyst Control Center. -
8+2 phase power design
To fully unleash the next-generation AM3 CPU's potential, the ASUS M4 series motherboards have adopted an 8-phase VRM power design. It delivers high power efficiency and supreme overclocking ability. Furthermore, high quality power components can effectively lower system temperature to ensure longer component lifespan. This series also features an extra 2 (or 1) phase power dedicated to integrated memory/HT controller. -
EPU (Energy Processing Unit)
The ASUS EPU (Energy Processing Unit) provides total system power management by detecting current PC loadings and intelligently moderating power in real-time. It automatically provides the most appropriate power usage for the CPU, VGA card, hard drives, and CPU/chassis fans- helping save power and money! ASUS EPU is supported by AM3/AM2+ CPU only. -
TurboV
Feel the adrenaline rush of real-time O.C. - now a reality with the ASUS TurboV. This easy O.C. tool allows you to overclock without exiting or rebooting the OS; and its user-friendly interface makes overclock with just a few clicks away. Moreover, the ASUS OC profiles in TurboV provide the best O.C. settings in different scenarios. -
Express Gate
Taking only 5 seconds to bootup, Express Gate is the one-stop gateway to instant fun! It's a unique motherboard built-in OS. You can utilize the most popular Instant Messengers (IM) like MSN, Skype, Google talk, QQ, and Yahoo! Messenger to keep in touch with friends, or quickly check on the weather and e-mails just before leaving your house. What's more, the user-friendly picture manager lets you view your pictures without entering Windows at anytime! -
Q- Shield
The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI). -
EZ-Flash 2
EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility. -
Stylish heatsink
The streamline-shaped heat-sink features 0-dB thermal solution that offers users a noiseless PC environment. Not only the beautifully curved fins upgrade the visual enjoyment for motherboard users, but also the special Streamline Airflow Guiding design lowers the temperature of the north bridge chipset through high efficient heat-exchange. Combined with usability and aesthetics, the ASUS streamline-shaped heat-sink will give users an extremely silent and cooling experience with the elegant appearance! -
DTS Surround Sensation UltraPC
DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, "Bass enhancement" provides stronger low frequency bass sound, and "Voice clarification" provides clear human dialog even with loud background sound. With these technologies, you may experience a better home-theater audio with ease. -
SATA on the go
The motherboard supports the next-generation hard drives based on the Serial ATA (SATA) 3Gb/s storage specification, delivering enhanced scalability and doubling the bus bandwidth for high-speed data retrieval and saves. The external SATA port located at the back I/O provides smart setup and hot-plug functions. Easily backup photos, videos and other entertainment contents on external devices. -
High definition audio
The onboard 8-channel HD audio CODEC enables high-quality 192KHz/24-bit audio output, jack-sensing feature, retaking functions and multi-streaming technology that simultaneously sends different audio streams to different destinations. You can now talk to your partners on the headphone while playing a multi-channel network games. All of these are done on one computer. -
S/PDIF-out on back I/O port
This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out (SONY-PHILIPS Digital Interface) jacks. It allows transferring digital audio without converting to analog format and keeps the best signal quality.
- ASUS M4A79XTD EVO - motherboard - ATX - Socket AM3 - AMD 790X
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD 790X / AMD SB750
- Processor Socket
- 1 x Socket AM3
- Compatible Processors
- Phenom II X3, Athlon II X2, Phenom II X2, Phenom II X4
- Max RAM Size
- 16 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
- Storage Ports
- 1 x ATA, 7 x SATA, 1 x eSATA
- USB / FireWire Ports
- FireWire
- USB Ports Configuration
- 12 x USB
- FireWire Ports Configuration
- 2 x FireWire
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Max Bus Speed
- 2600 MHz
- Processor Socket
- Socket AM3
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- VIA VT1708S
- DTS Surround Sensation UltraPC, High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe x1 , 2 x PCI
- Storage Interfaces
- AMD SB750: ATA-133 -connectors: 1 x 40pin IDC - 2 devices , AMD SB750: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 / JBOD , Marvell 88SE6121: SATA-300 -connectors: 1 x 7pin Serial ATA - 1 devices , Marvell 88SE6121: SATA-300 -connectors: 1 x 7pin external SATA - 1 devices
- 1 x PS/2 mouse , 1 x PS/2 keyboard , 8 x USB 2.0 , 1 x TOSLINK , 1 x FireWire , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone - mini-jack , 1 x audio line-out (rear) , 1 x audio line-out (center/subwoofer) , 1 x audio line-out (side surround)
- Internal Interfaces
- 1 x audio - 4 pin MPC
- Additional Connectors (Optional)
- 4 x USB 2.0, 1 x IEEE 1394 (FireWire)
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, SMBIOS 2.3 support, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support
- Manual Settings
- Processor core voltage, memory voltage, chipset voltage
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- Chassis intrusion detection, C.P.R. (CPU Parameter Recall), AMD Cool 'n' Quiet Technology, ASUS Q-Fan 2, jack retasking, ASUS Anti-Surge Protection, ASUS SATA on the Go, ASUS Turbo Key, CrashFree BIOS 3, ASUS Q-Connector, All-Solid Capacitor motherboard Design, ASUS Noise Filter, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, ASUS 8+2 Phase Power Design, ASUS Express Gate, ASUS TurboV, AMD CrossFireX technology support
- Cables Included
- 1 x IDE cable , 4 x Serial ATA cable
- Software Included
- ASUS Live Update, ASUS PC Probe 2, ASUS AI Suite, ASUS Express Gate, AMD OverDrive
- 30.5 cm
- 24.4 cm
- Limited warranty - 3 years
Asus M4A79XTD EVO, AMD 790X, AM3, 4DDR3, 2PCI-Ex16, CrossfireX Dualx8, Raid, 8 CHHD Sound, ATX
