This motherboard features an integrated Intel Celeron dual-core processor J1800 and Intel HD graphics. This revolutionary 22 nm ultra low voltage SoC (System On a Chip) combines superb processing power and advanced HD graphics support in one small, energy efficient design. Despite minimal power requirements, it still has the processing power to display the latest DirectX 11 HD graphics. It features support for dual independent displays with resolutions up to 2500 x 1600, and also has integrated USB 3.0 support.
Power efficiency plus high-resolution graphics, thanks to the integrated Intel Celeron dual-core SoC processor J1800 with HD graphics support
This motherboard features an integrated Intel Celeron dual-core processor J1800 and Intel HD graphics. This revolutionary 22 nm ultra low voltage SoC (System On a Chip) combines superb processing power and advanced HD graphics support in one small, energy efficient design. Despite minimal power requirements, it still has the processing power to display the latest DirectX 11 HD graphics. It features support for dual independent displays with resolutions up to 2500 x 1600, and also has integrated USB 3.0 support. -
Exclusive EZ mode adds useful info to become even easier
Media-renowned UEFI BIOS from ASUS provides the smoothest mouse-controlled graphical BIOS, and now features more intuitive functions to quickly take you to favorite BIOS pages and frequently-accessed settings through custom shortcuts. You can even write quick notes in-BIOS for future reference, view an activity log of setting changes and modifications, and rename SATA ports. EZ mode has beautiful look, upgraded with extra-friendly capabilities like detailed fan controls, XMP profile settings, SATA information, and fast clock adjustment. Together, these perfect your BIOS experience. -
USB 3.0 Boost (UASP support)
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) in Windows 8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance. -
AI Suite 3
ASUS AI Suite 3 offers excellent experience through a clearer and more attractive interface with support for larger monitors. It consolidates all exclusive ASUS features into one simple-to-use package, allowing you to supervise overclocking, energy consumption, fan speeds, voltages and more. This all-in-one app offers diverse and easy to use functionality, with no need to switch back and forth between different utilities. -
Green ASUS
Motherboards are EU Energy-related Products (ErP) ready, which requires products meet high efficiency standards with regards to energy consumption. This is in line with the ASUS vision of creating environmentally-friendly and energy-efficient products through design and innovation that reduce the carbon footprint of products and thus mitigate ecological impact.
- ASUS J1800I-C - motherboard - mini ITX - Intel Celeron J1800
- Product Type
- Motherboard - mini ITX
- Processor
- Intel Celeron J1800 (Dual-Core)
- Max RAM Size
- 8 GB
- RAM Supported
- 2 SO-DIMM slots - DDR3L, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-300
- USB / FireWire Ports
- 1 x USB 3.0 + 2 x USB 2.0 + (4 x USB 2.0 via headers)
- Graphics
- Intel HD Graphics
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Processor
Supported RAM
- Max Size
- 8 GB
- Technology
- DDR3L
- Bus Clock
- 1333 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- Graphics Controller
- Intel HD Graphics
- 512 MB
Audio
- Audio Codec
- Realtek ALC887-VD
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111G
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 2 x SO-DIMM 204-pin , 1 x PCIe 2.0 x1 , 1 x Mini PCIe
- Storage Interfaces
- SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
- 2 x USB 2.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.0 , 1 x PS/2 keyboard , 1 x VGA , 1 x PS/2 mouse , 1 x parallel , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 4 x USB 2.0 - header , 1 x serial - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, UEFI BIOS, ACPI 5.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS Fan Xpert, Conductive Polymer Capacitors, USB 3.0 Boost, ASUS Network iControl, Intel Smart Connect Technology, ASUS Boot Setting, Preboot eXecution Environment (PXE), Clear CMOS Button
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update
- Plug and Play, ACPI 2.0a
- 17 cm
- 17 cm
Asus J1800I-C mini ITX Intel Celeron J1800 USB 3.0 Gigabit LAN
