Exclusive Self-Build Special Bundle
High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this tested Intel Ultimate Bundle! We test it so you don't have to! Motherboard, CPU & Memory - Boxed & Ready To Rock!
Asus P9X79 PRO Intel Motherboard
All-New Digital Power Control for both CPU and DRAM:Absolute Performance on Intel X79 Platform
- Dual Intelligent Processors 3 with New DIGI+ Power Control
- Support for up to 64GB of system memory with an 8-DIMM design
- ASUS SSD Caching - 3X faster performance at a click
- UEFI BIOS - Full-scale performance tuning with easy BIOS Interface
- BT GO! (Bluetooth) - Diverse Bluetooth Enjoyment, a New Technology Lifestyle
- USB BIOS Flashback - Easy, worry-free USB BIOS Flashback
- 3-Way SLI and Quad-GPU CrossFireX Support!
ASUS X79 motherboard includes DIGI+ power control with three digital voltage controllers, including DRAM controllers that offers ultra-precise memory tuning in addition to ultra-precise CPU voltage control. This powerful ASUS technology provides excellent control for better efficiency, stability and performance.
ASUS facilitates strategic USB 3.0 accessibility for both the front and rear panel - 6 USB 3.0 ports in total. Experience the Plug and Play connectivity at speeds up to 10 times faster than USB 2.0. The P9X79 PRO affords greater convenience to high speed connectivity.
The world's first Dual Intelligent Processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control. This evolution of innovative and industry-leading ASUS technology provides super-accurate voltage tuning for better efficiency, stability and performance.
2nd Generation Intel® Core™ i7 Processor family for the LGA 2011 Socket
This motherboard supports the latest 2nd Generation Intel® Core™ i7 Processor family for the LGA 2011 Socket, with memory and PCI Express controllers integrated to quad-channel (8 DIMMs) DDR3 memory and 40 PCI Express 3.0 lanes. This provides great graphics performance. 2nd Generation Intel® Core™ i7 Processor family for the LGA 2011 Socket is one of the most powerful and energy efficient CPUs in the world.
Intel® X79 Express Chipset
The Intel® X79 Express Chipset is the latest single-chipset design that supports the 2nd Generation Intel® Core™ i7 Processor family for the LGA 2011 Socket. It improves performance by utilizing serial point-to-point links, allowing for increased bandwidth and stability. Additionally, the X79 comes with 2 SATA 6Gb/s and 4 SATA 3Gb/s ports for faster data retrieval, doubling the bandwidth of current bus systems
3-Way SLI™ and Quad-GPU CrossFireX™ Support
Both SLI and CrossfireX architectures work flawlessly on new ASUS X79 boards, with PCI Express slots designed to accommodate the power of up to four current graphics cards. Whether for professional graphics work, heavy duty multimedia or dedicated gaming, more than ample graphics power can be applied whenever needed.
Intel Core i7-3930K 3.20GHz LGA2011 12MB Cache Processor (BX80619I73930K)
Get the top-of-the-line unlocked processor that delivers 2nd generation smart performance at its best
Whether it's HD media, 3D gaming, or serious multitasking, unlock your full potential with the 2nd generation Intel® Core™ i7-3930K processor. With top-of-the-line adaptive speed1 and features, and overclocking enabled it delivers 2nd generation smart performance at its best with the flexibility to set your system specs just the way you like.
There are two words in your vocabulary that should never meet--Game and Over. You love playing, and you love winning, so you demand unmatched performance, the ability to customize your rig, and features that put you in control of the action. With Intel® technology inside your PC, you step into a heart-pounding experience. Pick up your weapon, challenge your friends, and never shut down.
Performance
- Automatically speeds up your processor when your PC needs extra performance--that's Intel® Turbo Boost Technology 2.0
- Features 12-way multi-task processing that allows each core of your processor to work on multiple tasks at the same time--that's Intel® Hyper-Threading Technology
- Higher frequency and larger cache size deliver even more responsiveness for the serious multitasker.
- High PCI Express* bandwidth support for multi-card Nvidia* SLI* and AMD* CrossFire* graphics configurations.
- Unlocked for the flexibility to tailor processor performance and power to match your needs.
- Overclocking enabled to allow tuning your system for extra performance.
Please note the new Intel Core i7-3930K Processors do not come with Heatsink & Fan, see bundles to attach
G.Skill RipJawsZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (F3-12800CL9Q-16GBZL)
G.Skill has announced the development of its brand new RipjawsZ series memory modules, designed specifically for Intel Sandy Bridge-E LGA1155 processors, and H67, P67, Z68 and X79 motherboard platforms. The new RipjawsZ series consists of a complete range of memory solution, from DDR3 1,600MHz, 1,866MHz, 2,133MHz, to 2,400MHz. Combined with the Intel's highly anticipated Sandy Bridge-E platform, G.Skill RipjawsZ series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsZ memory kit is hand-tested on an Intel Sandy Bridge-E platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsZ family.
- Model Name: F3-12800CL9Q-16GBZL
- XMP Profile version: 1.3
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- M/B Chipset: INTEL P67, INTEL X79
- CAS Latency: 9-9-9-24 2N
- Capacity: 16GB (4GBx4)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.5V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM
- Warranty: Lifetime
Digital power control for both CPU and DRAM
ASUS X79 motherboard includes DIGI+ power control with three digital voltage controllers, including DRAM controllers that offers ultra-precise memory tuning in addition to ultra-precise CPU voltage control. This powerful ASUS technology provides excellent control for better efficiency, stability and performance. -
Excellent power efficiency and stability
Two critical components work perfectly together to match digital power signal (SVID) requests from the CPU, with ultra-fast sensing and response to efficiently deliver the right level of power on demand. Accurate power reduces wasteful voltage imprecision, and provides more a stable CPU and memory setup. -
8 DIMM design - X79 done right
ASUS X79 motherboard is ideal for rendering detailed images or manipulating large files without the bottlenecks of conventional storage. It also allows users to set up big RAM disks and speed up frequently accessed programs, minimizing the impact of storage transfer delays while maximizing user benefit. -
3x faster performance at a click
SSD caching from ASUS is easier than ever. At 3x faster, this feature boosts system performance by using an installed SSD with no capacity limitations as a cache for frequently accessed data. Harness a combination of SSD-like performance and response and hard drive capacity with just one click, no rebooting needed and instant activation for complete ease of use, and even prevent data loss with included backup functionality. -
ASUS exclusive interface
EZ mode displays frequently-accessed info. Users can choose system performance settings and drag and drop boot priorities. Advanced mode for performance enthusiasts includes detailed DRAM settings via a dedicated memory info page for complete insight. -
Easy, worry-free USB BIOS flashback
USB BIOS flashback offers the convenient way to flash the BIOS! It allows overclockers to try more UEFI BIOS versions easily, without even entering their existing BIOS or operating system. It even works without key components such as the CPU and memory installed. Just plug in any USB storage and push the dedicated button for 3 seconds. The UEFI BIOS is automatically flashed using ATX standby power. -
Customizable speeds with independent fan control
Hardware-level ASUS fan Xpert+ allows users to independently adjust both CPU and case fan speeds with multiple dedicated controllers based on different ambient temperatures, climate conditions and system loads. Built-in profiles offer flexible automatic and manual fan speed controls to achieve a quiet and cool computing environment. -
Faster USB 3.0 transmission with UASP
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol). With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. ASUS software automatically accelerates data speeds for compatible USB 3.0 peripherals without the need for any user interaction. -
Double USB access, double convenience
ASUS facilitates strategic USB 3.0 accessibility for both the front and rear panel - 6 USB 3.0 ports in total. Experience Plug and Play connectivity at speeds up to 10 times faster than USB 2.0. The P9X79 PRO affords greater convenience to high speed connectivity. -
2x faster with fully charged power
Powered eSATA 6 Gb/s combines data and power connectivity. Users enjoy 2x faster transfer rates, and can use external SATA 6 Gb/s devices with no additional power adapters. ASUS provides two extra ports with enhanced scalability, faster data retrieval, and double the bandwidth of current bus systems for extra speed and accessibility. -
Expand your PC audio experience
To get the most out of your audio entertainment across all formats and quality levels, DTS connect combines two enabling technologies. DTS Neo: PC upmixes stereo sources (CDs, MP3s, WMAs, Internet radio) into as many as 7.1 channels of incredible surround sound. Consumers can then connect their PC to a home theater system. DTS interactive is capable of performing multi-channel encoding of DTS bitstreams on personal computers, and sending encoded bitstreams out of a digital audio connection designed to deliver audio to an external decoder.
- ASUS P9X79 PRO - motherboard - ATX - LGA2011 Socket - X79
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X79 Express
- Processor Socket
- 1 x LGA2011 Socket
- Compatible Processors
- Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 8 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 2 x powered eSATA-600
- USB / FireWire Ports
- 4 x USB 3.0 + 6 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X79 Express
- Processor Socket
- LGA2011 Socket
- Max Processors Qty
- 1
- Core i7
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500, PC3-15000
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- Realtek ALC898
- DTS Connect, High Definition Audio, DTS UltraPC II
LAN
- Network Controller
- Intel 82579V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 240-pin , 3 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9128: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , ASMedia ASM1061: SATA-600 -connectors: 2 x 11pin eSATAp - 2 devices
- 1 x TOSLINK , 6 x USB 2.0 , 4 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 1 x SPDIF out , 6 x USB 2.0 , 1 x USB 3.0 - header , 1 x audio
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.6 support, USB BIOS Flashback, UEFI BIOS
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- Jack retasking, MemOK!, ASUS Q-Design, ASUS EZ DIY, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, ASUS TurboV, ASUS BT GO!, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, ASUS SSD Caching, Dual Intelligent Processors 3, ASUS 8 + 2 Phase CPU Power Design, ASUS 2 + 2 Phase DRAM Power Design, ASUS BT Turbo Remote, Fanless Design Heat-pipe, ASUS Fan Xpert+, ASUS USB 3.0 Boost technology, AMD Quad CrossFireX technology support
- Included Accessories
- I/O back plate
- Cables Included
- 6 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Suite II, ASUS AI Charger
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 24.4 cm
- Limited warranty - 3 years
