Exclusive Self-Build Special Bundle
Perfect Performance PC!
Take the fear out of Self-Build with this tested Intel Performance Bundle! We test it so you don't have to! Motherboard & CPU - Boxed & Ready To Rock!
Asus P7P55D-E LX Intel Motherboard
This motherboard supports the latest Intel processors in LGA1156 package, which has memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, enabling higher graphics performance. Intel Lynnfield / Clarkdale processor is one of the most powerful and energy efficient CPU in the world. The Intel P55 Express chipset is the latest one-chipset design to support latest 1156 socket Intel Core i7/Core i5 processors.
Supporting next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Turn on IO Level Up to boost the USB 3.0 or SATA 6Gb/s data transfer rate to up to 500MB/s!
Intel Core i5 760 2.8GHz 8MB Processor (BX80605I5760)
With intelligent performance that accelerates in response to demanding tasks, such as playing games and editing photos, the Intel® Core™ i5 processor moves faster when you do. The Intel Core i5 processor automatically allocates processing power where it's needed most. Whether you're creating HD video, composing digital music, editing photos, or playing the coolest PC games-with the Intel Core i5 processor you can multitask with ease and be more productive than ever.
PCIe 2.0
This motherboard supports the PCIe 2.0 devices for double speed and bandwidth which enhances system performance. -
Intel P55
The Intel P55 Express Chipset is the one-chipset design to support 1156 socket Intel Core i7/Core i5 processors. Intel P55 providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. -
Dual-channel DDR3 2200(O.C.)/1600/1333/1066 support
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.)/1600 /1333/1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. -
True SATA 6Gbps support
Supporting next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0Gbps data transfer rates. -
IO level up
Turn on IO level up to boost the USB 3.0 or SATA 6Gbps data transfer rate to up to 500Mbps! Users can flexibly switch between full-speed PCIe x16 mode for their graphics cards and IO level up for rapid data throughput. -
True USB 3.0 support
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10x faster and is also backward compatible with USB 2.0 components. -
Easy, real-time O.C. tunings
Feel the adrenaline rush of real-time O.C. - now a reality with the ASUS TurboV. This easy O.C. tool allows you to overclock without exiting or rebooting the OS; and its user-friendly interface makes overclock with just a few clicks away. -
Auto system level up
Achieve extreme yet stable overclocking results automatically with auto tuning! With built-in stability testing, auto tuning lets even beginners improve performance with no additional cost. -
System level energy saving
The ASUS EPU - the world's first power saving engine, has been upgraded to a six engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. -
Fan Xpert
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, which is caused by different climate conditions in different geographic regions and system loading. -
ASUS Q-Design
ASUS Q-Design enhances your DIY experience. All of Q-LED and Q-DIMM design speed up and simplify the DIY process! -
EZ-Flash 2
EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility. -
Q-shield
The specially designed ASUS Q-shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI). -
O.C. Profile
The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings. -
Eliminate background noise while recording
This feature detects repetitive and stationary noises like computer fans, air conditioners, and other background noises then eliminates it in the incoming audio stream while recording. -
RoHS
The motherboard and its packaging comply with the European Union's Restriction on the use of Hazardous Substances (RoHS).
- ASUS P7P55D-E LX - motherboard - ATX - LGA1156 Socket - P55
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel P55 Express
- Processor Socket
- 1 x LGA1156 Socket
- Compatible Processors
- Pentium, Core i5, Core i3, Core i7
- Max RAM Size
- 16 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 1 x ATA, 8 x SATA, 1 x eSATA
- USB / FireWire Ports
- USB 3.0
- USB Ports Configuration
- 14 x USB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel P55 Express
- Processor Socket
- LGA1156 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- VIA VT1708S
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8112L
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 4 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , JMicron JMB361: ATA-133 -connectors: 1 x 40pin IDC - 2 devices , JMicron JMB361: SATA-300 -connectors: 1 x 7pin external SATA - 1 devices , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- RAID Features
- Intel Matrix RAID Technology
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 2 x USB 3.0 , 1 x storage - eSATA-300 - 7 pin external Serial ATA
- Additional Connectors (Optional)
- 6 x USB 2.0
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support
- Manual Settings
- CPU frequency, processor core voltage, memory voltage, PCI Express x16 slot frequency, chipset voltage
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Turbo Key, ASUS Q-Design, Stack Cool 3, Q-DIMM, IO Level UP, Q-LED, CrashFree BIOS 3, ASUS AI NET2, ASUS Noise Filter, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, ASUS Express Gate, ASUS Fan Xpert, ASUS TurboV, Intel Turbo Boost Technology
- Cables Included
- 1 x IDE cable , 3 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS Live Update
- Plug and Play, ACPI 2.0, RoHS
- 30.5 cm
- 21.8 cm
Asus Intel Performance Bundle (Includes Asus P7P55D-E LX Motherboard & Intel Core i5 760 2.8 GHz CPU)
