Asus GX1008 GigaX 8 x 10/100 Port Switch, enjoy long-lasting, trouble-free connections
Quicklinx: 72B6WS00 Mfr#: GX1008
The GX1008 V3 switches are an efficient, yet affordable, solution for the Home or SOHO Networks.
High performance Fast Ethernet switching is provided in a stylish, compact, power-saving design. The fan-less design also ensures for a quiet and peaceful working environment. With the quality that you have come to expect from ASUS, you can rest assured that your Network will enjoy long-lasting, trouble-free connections.
Green Network Technology saves up to 40% power comsumption
If the PC that connects to the ASUS GX1008 V3's LAN port is turned off, the switch will automatically put the specific port into standby mode, thus, achieving power savings up to 40%.
VIP Port, High Priority outgoing packets are sent without delay
When an insufficient bandwidth causes a queue for outgoing traffic, the ASUS GX1008 V3's built-in VIP LAN port ensures that high priority packets, such as a VoIP's RTP & Gaming stream, are sent without delay.
ASUS GigaX 1008 - switch - 8 ports
Switch - 8 ports
Subtype
Fast Ethernet
Ports
8 x 10/100
MAC Address Table Size
1K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
13.6 cm x 7.4 cm x 2.4 cm
0.3 kg
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100
1K entries
Status Indicators
Power, link/activity
8 x 100Base-TX RJ-45
External power adapter
TUV, VCCI, C-Tick, UL 1950, FCC Part 15 B, CCC, MIC
13.6 cm
7.4 cm
2.4 cm
0.3 kg
10 - 90%
