Introducing the world's first gaming supercomputer--GeForce® GTX TITAN.
The new ASUS Geforce® GTXTITAN-6GD5 graphics card ships with 28nm NVIDIA® GPU and 6GB GDDR5. To fully harness the power of the GPU technology, GTXTITAN-6GD5 comes with ASUS exclusive GPU Tweak utility and NVIDIA® GPU Boost clock 2.0 speed modulation that provides the fastest gaming performance.
ASUS Geforce® GTXTITAN-6GD5 offers gamers improved tuning access, and ultra-smooth gaming experience through NVIDIA® Adaptive VSync technology. It also supports NVIDIA® 3D Vision® surround™ on hundreds of PC games with a single card. Moreover, the card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0.
Now, you can get the same technology that powers the world's fastest supercomputer--Oak Ridge National Laboratory's Titan--in your gaming PC. GeForce GTX TITAN takes advantage of the NVIDIA® Kepler™ architecture to give you unprecedented levels of power, performance, and control, delivered with stunning craftsmanship. This means you can play the most graphics-intensive games at max settings and the highest frame rates--every title, every time.
GTX TITAN is supercomputing reimagined for PC gaming.
With the DNA of the world's fastest supercomputer and the soul of NVIDIA® Kepler™, GeForce® GTX TITAN is a revolution in PC gaming. GeForce GTX TITAN introduces a new class of gaming PCs: the gaming supercomputer. It delivers the superior combination of power, performance, efficiency, control, and acoustics that PC gamers demand in their favorite--and most challenging--titles.
The Gaming Supercomputer
Using the same Kepler architecture-based GPUs that power the world's fastest supercomputer, TITAN delivers extreme power and efficiency to the home gaming PC.
- Extraordinary power and efficiency
- 3-way NVIDIA SLI® technology for the most extreme PC gaming play
Precision Control
Get awesome power with absolute control to extract maximum performance.
- Pushes the PC to the maximum with precise controls using NVIDIA GPU Boost 2.0
- Provides users with advanced controls like GPU temperature target, overclocking, and overvoltage
Redefining the Gaming Experience
Offers a superior combination of power, performance, efficiency, control, and acoustics that PC gamers need for premium PC gaming
- Up to 4K resolution or multiple monitors
- Premium features like NVIDIA TXAA™, NVIDIA PhysX®, and NVIDIA 3D Vision®
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround™
- Support for four concurrent displays including:
- Two dual-link DVI
- HDMI1
- DisplayPort 1.2
- Microsoft DirectX 11.1 API (feature level 11_0)
- NVIDIA 3D Vision-Ready2
- NVIDIA SLI-Ready
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.3 support
- OpenCL™ support
A beauty--and a beast
- Combined beauty and power
- Beauty: GTX TITAN delivers refined design and capability to power smaller, elegant PC machines without sacrificing performance and efficiency
- Beast: GTX TITAN redefines the gaming experience with the power of supercomputer DNA with 3-way NVIDIA SLI®
Specifcations
- GPU GeForce GTX TITAN
- Core Base Clock 837 MHz
- Core Boost Clock 876 MHz
- Memory Clock 6008 MHz
- Memory Size 6144MB GDDR5
- Bus Type PCI Express 3.0
- Memory Bus 384-bit
- CUDA Cores 2688
- Memory type 64Mx32
- DirectX 11.1 Yes
- DVI Port DVI-I /DVI-D
- DisplayPort Yes
- HDCP Yes
- HDMI Yes
Real-time intuitive graphics tuning
Detailed specs and actual card status with GPU-Z, monitoring widget provides real-time and detailed multi-parameter info and automatically check and update drivers and BIOS versions. -
Gigantic GDDR5 memory
On-board memory is design for the best gaming experience and the best resolution. -
NVIDIA GPU Boost 2.0 intelligently monitors clock speed, ensuring that the GPU runs at its peak to push performance to new levels. -
Adaptive vertical sync
Get more than just faster frame rates. Get ultra-smooth gaming every time with NVIDIA gaming innovations - adaptive vertical sync. This technology dynamically adjusts Vsync to current frame rates for maximum playability. -
NVIDIA PhysX
Play games with advanced effects such as blazing explosions and lifelike characters with 10x faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time. -
NVIDIA 3D Vision surround ready
Transform hundreds of PC games into stereoscopic 3D and enjoy immersive full HD 3D gaming across three displays at an incredible 5760 x 1080 resolution. -
PCI Express 3.0
Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
- ASUS GTXTITAN-6GD5 - graphics card - GF GTX TITAN - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX TITAN
- Memory
- 6 GB GDDR5
- Core Clock
- 837 MHz
- Boost Clock
- 876 MHz
- CUDA Cores
- 2688
- Effective Memory Clock
- 6 GHz
- Memory Interface
- 384-bit
- DVI-I (dual link) , DVI-D (dual link) , DisplayPort , HDMI , VGA - with adapter
- API Supported
- DirectX 11.1, OpenGL 4.3
- 3.81 cm x 26.67 cm x 11.11 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 837 MHz
- Boost Clock
- 876 MHz
- CUDA Cores
- 2688
- API Supported
- Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia 3D Vision Surround Ready, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), NVIDIA GPU Boost 2.0, HDCP
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6 GHz
- Bus Width
- 384-bit
- Additional Requirements
- 6-pin + 8-pin power connectors
- 300 Watt
- Cables Included
- 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3.81 cm
- 26.67 cm
- 11.11 cm
