Asus GeForce GTX 970 OC TURBO 4GB GDDR5 PCIe3.0
Quicklinx: BLC6WS00 Mfr#: TURBO-GTX970-OC-4GD5
  • NVIDIA GeForce GTX 970
ASUS Turbo GTX 970 is a special-edition graphics card with distinctive coloring. Featuring an innovative modern dual-intake blower design and 10% larger heat-dissipation area, ASUS Turbo GTX 970 delivers 10% cooler performance and superior SLI configurations. It also comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive super alloy power components for superior stability.
ASUS Turbo GTX 970 enables you to squeeze every last drop of performance and lets you stream or record your gameplay instantly.
  • Dual-intake blower fan
    With 10% greater dissipation area and double-intake blower design, ASUS Turbo GTX 970 is 10% cooler than reference cards and 7% cooler when running SLI configurations. Tough ball-bearings on both sides of the fan housing provide greater strength and higher heat tolerance. With reduced friction, it also runs smoother, further improving 4X longer card lifespan.
  • Dual-ball bearing fan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Turbo GTX 970 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Super alloy power (enhanced durability and cooling)
    Exclusively formulated alloy components boost performance by reducing power loss, enhancing durability and facilitating cooler operation. Concrete-core chokes eliminate buzzing sounds under full load, and the card's capacitors have a 50,000-hour lifespan - 2.5X longer than traditional capacitors.
  • GPU Tweak: real-time intuitive graphics tuning
    Adjust clock speeds, voltages and fan speeds to tune your graphics card(s) exactly how you want to. Select between GPU Tweak's Standard or Advanced modes depending on your level of experience. Choose Standard Mode to access intuitive options for easy tweaking. This is great for those learning how to tune graphics cards. Alternatively try out the Advanced Mode for sophisticated and extensive tuning options that enable complete control for experienced overclockers.
  • XSplit Gamecaster: stream and record your gameplay instantly
    Now, you can also launch XSplitGamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
ASUS TURBO-GTX970-OC-4GD5 - graphics card - GF GTX 970 - 4 GB - white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1088 MHz
Boost Clock
1228 MHz
CUDA Cores
1664
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.4
3.7 cm x 26.4 cm x 12.1 cm
Enclosure Colour
White
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1088 MHz
Boost Clock
1228 MHz
CUDA Cores
1664
API Supported
OpenGL 4.4
Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Super Alloy Power technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, Dual ball Bearing Fan, NVIDIA GPU Boost 2.0, GPU Tweak Streaming, Dual-intake Blower Fan, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Additional Requirements
8 pin PCI Express power connector
225 Watt
Software Included
Display drivers, ASUS GPU Tweak, XSplit Gamecaster (1 year Premium licence)
3.7 cm
26.4 cm
12.1 cm
Enclosure Colour
White
