Asus GeForce GTX 970 4GB PCI-Express 3.0 DirectCU II OC STRIX
Quicklinx: 9RXDWS00 Mfr#: STRIX-GTX970-DC2OC-4GD5
  • NVIDIA GeForce GTX 970
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
ASUS Strix GTX 970 gaming graphics card is factory-overclocked at 1253 MHz and packed with exclusive ASUS technologies, including DirectCU II to deliver cooler, quieter, and faster performance for incredible action gaming experiences. Strix GTX 970 also features 0 dB fan technology to let gamers enjoy total silence during light gameplay as well as Blu-ray movie playback free from distracting background noise. Strix GTX 970 features exclusive ASUS DIGI+ VRM with 6-phase Super Alloy Power components for enhanced durability and cooling, and GPU Tweak for overclocking and online streaming.
  • DirectCU II with 0 dB fan technology - 30% cooler, silent gaming
    Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10 mm heatpipe that transports 40% more heat away from the GPU - a first for the industry! The design also includes 220%-larger heat-dissipation: this means performance that's 30% and three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0 dB fan technology that lets you enjoy games like League of Legends and StarCraft in complete silence - because the fan stops completely when the GPU temperature remains below a set level.
  • DIGI+ VRM with Super Alloy Power - 30% less power noise and 2.5x greater durability
    Acclaimed DIGI+ VRM has been applied via a 6-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference.
  • GPU Tweak with streaming real-time intuitive graphics tuning
    Shows detailed specs and actual card status with GPU-Z; monitoring widget provides real-time detailed multi-parameter info; automatically checks and updates drivers and BIOS versions.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS STRIX-GTX970-DC2OC-4GD5 - graphics card - GF GTX 970 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1114 MHz
Boost Clock
1253 MHz
CUDA Cores
1664
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
DVI-I , DVI-D , HDMI , DisplayPort
4 cm x 28 cm x 14 cm
Microsoft Certification
Compatible with Windows 7
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1114 MHz
Boost Clock
1253 MHz
CUDA Cores
1664
Dual Slot Fan Cooler, Super Alloy Power technology, 6 Phase PWM Design, ASUS DIGI+ VRM, GPU Tweak Streaming, ASUS DirectCU II with 0dB Fan Technology, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Additional Requirements
8 pin PCI Express power connector
225 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
4 cm
28 cm
14 cm
Limited warranty - parts and labour - 3 years
