Asus GeForce GTX 960 STRIX OC 4GB GDDR5 DP/HDMI/DVI/PCI-E Graphics Card
Quicklinx: B4ZTWS00 Mfr#: STRIX-GTX960-DC2OC-4GD5
  • NVIDIA GeForce GTX 960
ASUS Strix GeForce GTX 960 with factory-overclocked core delivers cool and silent gaming experiences
1291MHz factory-overclocked GPU
1317MHz GPU boost clock in OC mode
DirectCU with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming 30% cooler with 3X-quieter performance!
Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
GPU Tweak with XSplit Gamecaster: Real-time and intuitive GPU clock boost, and live-stream your gameplay instantly
STRIX
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
ASUS Strix GTX 960, an all new gaming graphics card packed with exclusive ASUS technologies, including DirectCU II for cooler, quieter and faster performance for incredible action gaming, and 0dB fan technology for light gameplay in total silence.
The new card features feature exclusive ASUS Super Alloy Power components and backplate design for enhanced durability and cooling, and GPU Tweak with XSplit Gamecaster for overclocking and online streaming that's as simple as it is flexible. Strix GTX 960 comes equipped with a DisplayPort interface to support connections up to 4K/UHD (ultra-high definition) resolution.
Strix GTX 960 is factory-overclocked at 1291 MHz and has a 1317 MHz boost clock speed in OC Mode that delivers stunning gaming performance. Strix GTX 960 provides 12% faster gameplay in Assassin's Creed® Unity and Battlefield 4™, and runs the 3DMark 11 (Extreme) benchmark at 1920 x 1080 Full HD resolution 6.5% faster than reference designs. It is fitted with 4 GB of high-speed GDDR5 video memory that races along at boosted speeds of up to 7010 MHz.
DirectCU II with 0dB Fan Technology
30% cooler. Silent gaming.
Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU — a first for the industry! The design also includes 220%-larger heat-dissipation: this means performance that's 30% and three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0dB fan technology that lets you enjoy games like League of Legends® and StarCraft® in complete silence — because the fan stops completely when the GPU temperature remains below a set level.
Super Alloy Power
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
GPU Tweak with Streaming
Real-time intuitive graphics tuning
- Shows detailed specs and actual card status with GPU-Z
- Monitoring widget provides real-time detailed multi-parameter info
- Automatically checks and updates drivers and BIOS versions
XSplit Gamecaster x GPU Tweak
XSplit Gamecaster lets you easily stream and record your greatest gaming moments at the click of a button. It's simple, easy to use, and perfect for sharing your gameplay with the world. ASUS GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface. Download XSplit Gamecaster today and get a 1 year FREE XSplit Premium License.
  • DirectCU II with 0dB Fan Technology
    Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU - a first for the industry! The design also includes 220%-larger heat-dissipation: this means performance that's 30% and three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0dB fan technology that lets you enjoy games like League of Legends and StarCraft in complete silence - because the fan stops completely when the GPU temperature remains below a set level.
  • Enhanced durability and cooling
  • XSplit Gamecaster x GPU Tweak
ASUS STRIX-GTX960-DC2OC-4GD5 - graphics card - GF GTX 960 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1253 MHz
Boost Clock
1317 MHz
CUDA Cores
1024
Effective Memory Clock
7.01 GHz
Memory Interface
128-bit
Interfaces Details
DVI-I (dual link) , HDMI , 3 x DisplayPort , VGA - with adapter
4.09 cm x 21.52 cm x 12.12 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1253 MHz
Boost Clock
1317 MHz
CUDA Cores
1024
Interfaces Details
Dual Slot Fan Cooler, Dual Fan Design, Super Alloy Power technology, GPU Tweak Streaming, ASUS DirectCU II with 0dB Fan Technology
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
128-bit
150 Watt
1 x DVI-VGA adapter
Software Included
Display drivers, ASUS GPU Tweak
4.09 cm
21.52 cm
12.12 cm
