ASUS STRIX GTX 950 gaming graphics cards packed with exclusive ASUS technologies, including DirectCU II with Dual Wing-Blade 0dB Fan Design for maximum air flow with 20% cooler and 3X quieter performance. This card features exclusive ASUS Auto-Extreme technology with Super Alloy Power II for premium quality and best reliability. It also has GPU Tweak II with Xsplit Gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
DirectCU II with 10mm heatpipe
Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU - a first for the industry! The design also includes 2.8X-larger heat-dissipation: this means performance that's 20% cooler three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. -
Dual wing-blade 0dB fan design
DirectCU II features dual 0dB fans engineered with a patented, new wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games like League of Legends and StarCraft in complete silence - because the fan stops completely when the GPU temperature remains below a set level. -
All ASUS graphics cards are now produced using AUTO-EXTREME Technology, an industry-first, 100% automated production process that incorporates premium materials to set a new standard of quality. AUTO-EXTREME Technology ensures consistent graphics card quality as well as improved performance and longevity. This new manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%. -
5-phase Super Alloy Power II
ASUS engineers have integrated premium components into their graphics card designs to reinforce overall reliability. Super Alloy Power II components greatly enhance efficiency, reduce power loss, provide 2X reduced component buzzing while under full load, and achieve thermal levels that are approximately 50% cooler than previous designs. -
GPU Tweak II with XSplit Gamecaster
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
- ASUS STRIX-GTX950-DC2OC-2GD5-GAMING - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1165 MHz
- Boost Clock
- 1355 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6.61 GHz
- Memory Interface
- 128-bit
- DVI-I , HDMI , DisplayPort , DVI-D
- API Supported
- OpenGL 4.5
- 4 cm x 22 cm x 12.5 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1165 MHz
- Boost Clock
- 1355 MHz
- CUDA Cores
- 768
- API Supported
- OpenGL 4.5
- Native HDMI, ASUS DIGI+ VRM, Super Alloy Power II technology, AUTO-EXTREME technology, DirectCU II with Dual Wing-Blade 0dB Fan Design, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- Additional Requirements
- 6 pin PCI Express power connector
- 150 Watt
- Included Accessories
- STRIX Laser Sticker
- Software Included
- Display drivers, ASUS GPU Tweak II
- 4 cm
- 22 cm
- 12.5 cm
