ASUS GTX 950 is an astonishing graphics card - with distinctive white coloring. Featuring a dual fan cooling technology, ASUS GTX 950 delivers 2X greater airflow and 3X quieter performance. It also comes equipped with AUTO-EXTREME technology and Super Alloy Power II for premium quality and best reliability.
Optimized style and performance
ASUS GTX 950 graphics card and Z170 motherboards share perfectly matching color themes and are ready for Windows 10. GTX 950 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks. -
2X greater airflow, 3X quieter
Twin optimized fans carefully selected by engineers drive 2X greater airflow while maintaining 3X quieter performance, combining enhanced cooling with a more pleasant gaming and computing environment. -
Premium quality and best reliability
ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
- ASUS GTX950-OC-2GD5 - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1102 MHz
- Boost Clock
- 1279 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6.61 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 21 cm x 11.3 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1102 MHz
- Boost Clock
- 1279 MHz
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160
- API Supported
- Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Dual Fan Design, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, GPU Tweak Streaming, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- Software Included
- Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
- 4 cm
- 21 cm
- 11.3 cm
