Echelon GTX 950 is a gaming graphics card designed with astonishing looks and unstoppable performance. It features DirectCU II with a dual-ball-bearing fan for a longer lifespan. Its Auto-Extreme technology and military-grade TUF components ensure premium quality and reliability for tough, dependable service.
Military tough and combat ready
Echelon GTX 950 is a gaming graphics card designed with astonishing looks and unstoppable performance. It features DirectCU II with a dual-ball-bearing fan for a longer lifespan than reference cards. Industry-exclusive Auto-Extreme technology and military-grade TUF components ensure premium quality and reliability for tough, dependable service. -
Dual-ball bearing fan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan lasts significantly longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. -
Auto-Extreme technology with TUF components
GTX 950 is produced using Auto-Extreme technology, an ultimate fully automated production process for premium quality and reliability. With military-grade TUF capacitors with a longer lifespan than standard capacitors and strong alloy chokes that provide better heat-dissipation round out a set of onboard components, so you can be confident of high durability and reliability.
- ASUS ECHELON-GTX950-O2G - OC Edition - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1165 MHz
- Boost Clock
- 1355 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6.61 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Interfaces Details
- DVI-I , HDMI , DisplayPort , DVI-D
- API Supported
- OpenGL 4.5
- 3.9 cm x 22 cm x 12.5 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1165 MHz
- Boost Clock
- 1355 MHz
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.5
- Dual Slot Fan Cooler, Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Military Class Components, ASUS DirectCU II Technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, Dual ball Bearing Fan, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, AUTO-EXTREME technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- Additional Requirements
- 6 pin PCI Express power connector
- 150 Watt
- Software Included
- Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
- 3.9 cm
- 22 cm
- 12.5 cm
