Small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce GTX 950 mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative thermal design that combines a heat-spreading vapor chamber and the CoolTech fan, which uses wide-angle airflow and venting to cool critical graphics card components.
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
Go mini, game big
Small form factor PCs based on mini ITX motherboards are a popular choice for gamers and home users. Their compact cases are much easier to transport to LAN parties than a standard desktop PC, and stylish designs with comparatively low power requirements make them a natural choice for home theater PCs. The ASUS GeForce GTX 950 Mini is designed to maximize the potential offered by mini ITX motherboards by delivering high performance graphics. It uses an innovative thermal design that combines a heat-spreading vapor chamber and the CoolTech fan, which uses wide-angle airflow and venting to cool critical graphics card components. -
Premium quality and best reliability
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability. -
GPU Tweak II with XSplit Gamecaster - tweak till your heart's content
Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay. -
XSplit Gamecaster: stream and record your gameplay instantly
Now, you can also launch XSplit Gamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
- ASUS GTX950-M-2GD5 - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1026 MHz
- Boost Clock
- 1190 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6.61 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- DVI-I , DisplayPort , HDMI
- API Supported
- OpenGL 4.5
- 4 cm x 17.2 cm x 11.2 cm
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1026 MHz
- Boost Clock
- 1190 MHz
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.5
- Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, CoolTech Fan, GPU Tweak Streaming, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- Additional Requirements
- 6 pin PCI Express power connector
- 150 Watt
- Software Included
- Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
- 4 cm
- 17.2 cm
- 11.2 cm
- Limited warranty - 3 years
