Asus GeForce GTX 950 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C0QZWS00 Mfr#: GTX950-2G
ASUS GTX 950 is an astonishing graphics card - with distinctive white coloring. Featuring a dual fan cooling technology, ASUS GTX 950 delivers 2X greater airflow and 3X quieter performance. It also comes equipped with AUTO-EXTREME technology and Super Alloy Power II for premium quality and best reliability. With 14-days free premium license of customized ASUS GPU Tweak II and XSplit Gamecaster utility, ASUS GTX 950 enables you to squeeze every last drop of performance and lets you stream or record your gameplay instantly. It also comes with a World of Warships invite code for a free 15-day premium account and an exclusive Diana Cruiser. Claim your code and win some battles!
ASUS GTX 950 graphics card and Z170 motherboards share perfectly matching color themes and are ready for Windows 10. GTX 950 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
Twin optimized fans carefully selected by engineers drive 2X greater airflow while maintaining 3X quieter performance, combining enhanced cooling with a more pleasant gaming and computing environment.
  • Be unique, stand out from the crowd
  • Perfectly matched with ASUS Z170 motherboards
  • Dual fan cooling
  • AUTO-EXTREME technology with Super Alloy Power II
    ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
ASUS GTX950-2G - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1051 MHz
Boost Clock
1228 MHz
CUDA Cores
768
Effective Memory Clock
6.61 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Interfaces Details
DVI-I , DisplayPort , HDMI
API Supported
OpenGL 4.5
4 cm x 21 cm x 11.3 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1051 MHz
Boost Clock
1228 MHz
CUDA Cores
768
Max Resolution
4096 x 2160
Interfaces Details
API Supported
OpenGL 4.5
Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Dual Fan Design, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.61 GHz
Bus Width
128-bit
75 Watt
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
4 cm
21 cm
11.3 cm
