Asus GeForce GTX 760 1033MHz 2GB PCI-Express 3.0 HDMI DirectCU II
Quicklinx: 9JFJWS00 Mfr#: GTX760-DC2-2GD5
  • NVIDIA GeForce GTX 760
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
ASUS GeForce® GTX 760 DirectCU II cool graphics for PCs of all sizes
  • DirectCU II achieves 20% lower temps with direct-contact copper heatpipes while running 2 times quieter than reference
  • Direct Power ensures stable performance with 56% less impedance and a 17% cooler PCB
  • Super Alloy Power components increase product longevity by up to 2.5X compared to reference
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
Cool Performance Inside Out
  • DirectCU II: 20% cooler and vastly quieter. Flattened copper heatpipes make direct contact with GPU surfaces so heat is dissipated efficiently, delivering 20% cooler and vastly quieter performance than reference.
  • Direct Power: A custom PCB and VRM design featuring Direct Power technology. This provides high quality and reliable power delivery to the GPU, whether for gaming or overclocking. In addition, superior efficiency reduces PCB temperatures by 17%.
  • GPU Tweak: Real-time intuitive graphics tuning. Shows detailed specs and actual card status with GPU-Z, Monitoring widget provides real-time detailed multi-parameter info and automatically checks and updates drivers and BIOS versions
  • Gigantic 2GB GDDR5 Memory: On-board memory for the best gaming experience & the best resolution
I/O Ports Highlight
  • 1x Native Dual-link DVI-I
  • 1x Native Dual-link DVI-D
  • 1x Native HDMI
  • 1x Native DisplayPort
  • Graphics Engine: NVIDIA GeForce GTX 760
  • Bus Standard: PCI Express 3.0
  • Video Memory: GDDR5 2GB
  • Engine Clock: GPU Boost Clock : 1033 MHz / GPU Base Clock : 980 MHz
  • CUDA Core: 1152
  • Memory Clock: 6008 MHz ( GDDR5 )
  • Memory Interface: 256-bit
  • Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D), HDMI Output : Yes x 1 , Display Port : Yes x 1 (Regular DP)
  • HDCP Support : Yes
  • Power Consumption: up to 225W1 additional 8 pin PCIe power required
  • Accessories: 1 x Power cable
  • Software: ASUS GPU Tweak & Driver
  • ASUS Features: DirectCU Series, Super Alloy Power
  • Dimensions: 8.6 " x 5 " x 1.5 " Inch / 21.84 x 12.7 x3.81 Centimeter
  • 20% cooler and vastly quieter
  • Direct power
  • NVIDIA GPU Boost 2.0
    Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers more levels of customization, including GPU temperature target, overclocking, and unlocked voltage.
  • NVIDIA Adaptive V-Sync
    Get more than just faster frame rates. Get ultra-smooth gaming every time with NVIDIA gaming innovation Adaptive Vertical Sync. This technology dynamically adjusts vsync to current frame rates for maximum playability.
  • NVIDIA PhysX
    Play games with advanced effects such as blazing explosions and lifelike characters with 10x faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
  • SLI support
    Multi-GPU technology for extreme performance.
  • NVIDIA 3D Vision
    Transform hunreds of PC games into stereoscopic 3D and enjoy immersive Full HD 3D gaming across three displays at an incredible 5760 x 1080 resolution.
  • PCI Express 3.0
    Delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
  • Microsoft DirectX 11.1 API
    Brings more levels of visual realism to gaming on the PC and get top-notch performance.
ASUS GTX760-DC2-2GD5 - graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
980 MHz
Boost Clock
1033 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
API Supported
DirectX 11.1
3.81 cm x 21.84 cm x 12.7 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
980 MHz
Boost Clock
1033 MHz
CUDA Cores
1152
API Supported
DirectX 11.1
Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Super Alloy Power technology, ASUS DirectCU II Technology, Nvidia SLI ready, Adaptive V-Sync, NVIDIA GPU Boost 2.0, Direct Power technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Additional Requirements
8 pin PCI Express power connector
225 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.81 cm
21.84 cm
12.7 cm
