Asus GeForce GTX 760 1006MHz 2GB PCI-Express 3.0 HDMI DirectCU II OC
Quicklinx: 8SWQWS00 Mfr#: GTX760-DC2OC-2GD5
  • NVIDIA GeForce GTX 760
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Dunc's Deal Alert: dabs.com exclusive!
From September 1st - September 30th 2014 anyone who buys one of these Asus GeForce GTX 760 1006MHz 2GB Graphics Card will be able to claim Borderlands The Pre-Sequel for FREE! Once ordered email duncsdeals@dabs.com with your Sales Order Number to claim!
ASUS GeForce® GTX 760 DirectCU II bring sweet spot performance
  • DirectCU II achieves 20% lower temps with direct-contact copper heatpipes while running vastly quieter than reference
  • Direct Power ensures stable performance with 56% less impedance and a 17% cooler PCB
  • Super Alloy Power components increase product longevity by up to 2.5X compared to reference
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
Flattened copper heatpipes make direct contact with GPU surfaces so heat is dissipated efficiently, delivering 20% cooler and vastly quieter performance than reference.
A custom PCB and VRM design featuring Direct Power technology. This provides high quality and reliable power delivery to the GPU, whether for gaming or overclocking. In addition, superior efficiency reduces PCB temperatures by 17%. Get more than just faster frame rates. Get ultra-smooth gaming every time with NVIDIA gaming innovation Adaptive Vertical Sync. This technology dynamically adjusts vsync to current frame rates for maximum playability.
  • 20% cooler and vastly quieter
  • OC-selected 1072 MHz core
    1072 MHz Boost clock for better performance and outstanding gaming experience.
  • Direct Power technology
  • NVIDIA Adaptive V-Sync
  • NVIDIA PhysX
    Play games with advanced effects such as blazing explosions and lifelike characters with 10x faster switching between graphics and physics processing, enabling more complex effects to be rendered in real time.
  • NVIDIA 3D Vision
    Transform hunreds of PC games into stereoscopic 3D and enjoy immersive Full HD 3D gaming across three displays at an incredible 5760 x 1080 resolution.
  • PCI Express 3.0
    It delivers double the bandwidth per lane of PCIe 2.0 for faster GPU-CPU communication.
ASUS GTX760-DC2OC-2GD5 - graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Interfaces Details
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort
API Supported
DirectX 11.1, OpenGL 4.3
3.81 cm x 21.84 cm x 12.7 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
Interfaces Details
API Supported
Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Super Alloy Power technology, ASUS DirectCU II Technology, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, Direct Power technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
225 Watt
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.81 cm
21.84 cm
12.7 cm
