Asus GeForce GTX 750 1GB PCI-E 3.0 HDMI OC
Quicklinx: 98K5WS00 Mfr#: GTX750-PHOC-1GD5
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
The ASUS GTX 750 is a new high-value 3D-gaming graphics card equipped respectively with a powerful GeForce® GTX 750 graphics-processing unit (GPU) and overclocked for performance that's up to 52MHz faster than reference. The GTX 750 card benefit from many exclusive ASUS technologies and tools including dust-proof fans for improved card lifespan and Super Alloy Power components for superior stability. They also include GPU Tweak, an easy-to-use tuning software that helps users to squeeze every last drop of performance out of their graphics card and stream on-screen action over the internet in real time - great for boasting rights.
GTX 750 has a 1059MHz overclocked base clock that runs as fast as 1137MHz when boosted- so the latest 3D games can be enjoyed at very high detail levels of up to 2560 x 1600 pixels with no slowdown.
This card also benefits from a unique fan design and layout that dissipates heat efficiently while offering highly-effective resistance to the intake of dust and other particulates.
This card features exclusive ASUS Super Alloy Power components. Super Alloy Power's concrete-core chokes and hardened MOSFETs withstand much greater stress and heat thanks to the application of specially-formulated materials, while minimized power loss, enhanced durability and cooler operation ensure that the GTX 750's components last much longer than references - up to two-and-a-half (2.5X) times longer, in fact.
The GTX 750 is supplied with GPU Tweak, an exclusive ASUS tool that helps users to push the cards' GPUs to their limits - easily and safely. The utility includes the ability to control finely GPU and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds in real time, all via an intuitive interface.
As well, the GPU Tweak Streaming tool lets users share on-screen action over the internet in real time, so others can watch live as games are played. It's even possible to add a title to the streaming window along with scrolling text, pictures and webcam images. The GTX 750 also offers support for the latest DirectX® 11.2 standard (up to API feature level 11_0), which allows on-GPU tessellation that delivers more and incredibly detailed geometry to be packed into every game scene - characters come to life with detail levels that rival blockbuster movies. This card also includes NVIDIA PhysX® technology that enables games to provide much more accurate simulations of real-world physical interactions, including brilliant dynamic effects such as blazing explosions, rippling water and debris that reacts just as it would in the real world.
  • NVIDIA TXAA Technology
  • NVIDIA GPU Boost 2.0
  • NVIDIA PhysX Technology
  • NVIDIA FXAA Technology
  • NVIDIA Adaptive Vertical Sync
  • NVIDIA 3D Vision-Ready
  • NVIDIA CUDA Technology
  • 25% longer graphics card lifespan
    Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
  • Enhanced durability and cooling
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS GTX750-PHOC-1GD5 - graphics card - GF GTX 750 - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 - up to
1 GB GDDR5
Core Clock
1059 MHz
Boost Clock
1137 MHz
CUDA Cores
512
Effective Memory Clock
5.01 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Interfaces Details
DVI-D (dual link) , VGA , HDMI
API Supported
DirectX 11
3.58 cm x 18.49 cm x 11.5 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1059 MHz
Boost Clock
1137 MHz
CUDA Cores
512
Max Resolution
2560 x 1600
Interfaces Details
API Supported
DirectX 11
Native HDMI, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, GPU Tweak Streaming, HDCP
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.01 GHz
Bus Width
128-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.58 cm
18.49 cm
11.5 cm
