- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
ASUS Exclusive DirectCU Thermal Solution: Two 8mm flattened copper heat-pipes to contact GPU directly for up to 20% COOLER than generic GeForce GTX460.
Graphics Engine GeForce GTX460
- Bus Standard PCI Express® 2.0
- Video Memory 768MB GDDR5
- Engine Clock 700 MHz
- CUDA Core Clock 1400MHz
- Memory Clock 3680MHz (920MHz GDDR5)
- Memory Interface 192bit
- DVI Max. Resolution 2560 * 1600
- DSub Max. Resolution 2048 * 1536
- DVI Output 2x Native Dual-link DVI-I
- HDMI Output 1x Native HDMI (Mini HDMI)
- D-Sub Output 1x via adapter
- HDCP compliant YES
- Software Bundled ASUS Utilities & Driver
- Note The card size is 9.46" x 4.73" inch
