Asus GeForce GTX 1070 TURBO 8GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C8WCWS00 Mfr#: TURBO-GTX1070-8G
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
ASUS Turbo GeForce® GTX 1070 graphics deliver the sweet spot of performance
Dual-ball Bearing Fan runs smoother by reducing friction, further improving 4X longer card lifespan and cooling efficiency.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-friendly HDMI Ports for immersive virtual reality experiences.
Customizable Backlit Logo gives your system a truly unique look with your own LED backlit logo design.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
Perfect Your Build
ASUS Turbo GeForce® GTX 1070 comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences. ASUS Turbo GeForce® GTX 1070 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
Dual-Ball Bearing Fan
4X longer lifespan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Turbo GeForce® GTX 1070 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
Premium quality and best reliability
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
VR-Friendly HDMI Ports
Enjoy immersive virtual reality experience
ASUS Turbo GeForce® GTX 1070 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
An unique look for your system
ASUS Turbo GeForce® GTX 1070 comes with an LED backlit ASUS logo that you can swap with your own custom design for a truly unique look.
  • Perfect your build
    ASUS Turbo GeForce GTX 1070 comes equipped with a dual ball-bearing fan for a 4X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences. ASUS Turbo GeForce GTX 1070 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming.
  • Dual-ball bearing fan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Turbo GeForce GTX 1070 lasts 4X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • VR-friendly HDMI ports
    ASUS Turbo GeForce GTX 1070 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
ASUS TURBO-GTX1070-8G - graphics card - GF GTX 1070 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1070 - up to
8 GB GDDR5
Core Clock
1506 MHz
Boost Clock
1683 MHz
CUDA Cores
1920
Effective Memory Clock
8.008 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
OpenGL 4.5
3.81 cm x 26.67 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1506 MHz
Boost Clock
1683 MHz
CUDA Cores
1920
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Dual Slot Fan Cooler, Native HDMI, Nvidia SLI ready, Dual ball Bearing Fan, GPU Tweak Streaming, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
256-bit
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
3.81 cm
26.67 cm
11.12 cm
