Asus GeForce GTX 1050 Ti 4GB GDDR5 PCIe 3.0 Graphics Card
Quicklinx: CGF1WS00 Mfr#: PH-GTX1050TI-4G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
ASUS Phoenix GeForce® GTX 1050 Ti 4GB GDDR5 is the best for compact gaming PC build:
Exclusive World of Warships invite code for free: Diana Cruiser and 15-day Premium Account (worth USD11). - game codes redemption starts from 7/31/2015 to 1/30/2017. Please stay tuned on http://www.asus.com/event for details.
Dual-ball Bearing Fan reduces spinning friction for 2 times longer lifespan and cooling efficiency.
Easy plug and play gaming with no extra power supply needed.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
GPU Tweak II with XSplit Gamecaster provides intuitive performance tweaking and real-time streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
The Best for Your Compact Build
ASUS Phoenix GeForce® GTX 1050 Ti comes equipped with a dual ball-bearing fan for a 2X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. ASUS Phoenix GeForce® GTX 1050 Ti also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and real-time streaming. It provides best experience in games such as Overwatch, Dota 2, CS Go and League of Legend.
I/O Ports Highlight
1 X Native DVI-D
1 X Native HDMI 2.0
1 X Native DisplayPort
Dual-Ball Bearing Fan
2X Longer Lifespan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Phoenix GeForce® GTX 1050 Ti lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
Premium quality and the best reliability
ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
Tweak Till Your Heart's Content
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
  • Great for your compact build
    ASUS Phoenix GeForce GTX 1050 Ti comes equipped with a dual ball-bearing fan for a 2X longer card lifespan and exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. ASUS Phoenix GeForce GTX 1050 Ti also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and real-time streaming.
  • 2X longer lifespan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Phoenix GeForce GTX 1050 Ti lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Premium quality and the best reliability
    ASUS graphics cards are produced using Auto-Extreme technology, a 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • GPU Tweak II with XSplit Gamecaster
    Redesigned with an intuitive, UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
ASUS PH-GTX1050TI-4G - graphics card - GF GTX 1050 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1050 Ti - up to
4 GB GDDR5
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.5
3.7 cm x 19.2 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1290 MHz
Boost Clock
1392 MHz
CUDA Cores
768
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Native HDMI, NVIDIA Adaptive Vertical Sync, Dual ball Bearing Fan, NVIDIA GPU Boost 2.0, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, NVIDIA Ansel, NVIDIA Pascal GPU technology, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster 2 (14 days Premium licence)
3.7 cm
19.2 cm
11.1 cm
