Asus GeForce GT 740 2GB PCI-Express 3.0 HDMI
Quicklinx: 9HTWWS00 Mfr#: GT740-2GD3
  • High-Definition Multimedia Interface (HDMI)
Key Features
  • GPU Tweak
  • GeForce CUDA Support
  • NVIDIA Adaptive V-Sync
  • NVIDIA PhysX ready
  • NVIDIA 3D Vision Surround Ready
  • Chipset: NVIDIA GeForce GT 740
  • Interface: PCI Express 3.0
  • Video Memory: 2GB
  • Memory Type: GDDR5
  • Stream Processing Units: 384
  • DirectX Support: 11
  • OpenGL Support: 4.4
Package Contents
  • Video Card
  • Manual
  • Support Disk
  • Raging cool for the win
    GT 740 is an astonishing graphics card from ASUS - that's astonishing 3D gaming and astonishing value! Equipped with the powerful GeForce GT 740 graphics-processing unit (GPU) and GT 740 treats you to smoother, faster and more detailed gaming experiences. GT 740 includes some brilliant technologies that you can get only from ASUS. GT 740 also comes with the easy-to-use tuning tool, GPU tweak. Use this to squeeze every last drop of performance out of the card and then stream your sound-up on-screen action over the Internet in real time!
  • Dust-proof fan
    Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
  • Super alloy power
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation.
ASUS GT740-2GD3 - graphics card - GF GT 740 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GT 740 - up to
2 GB DDR3
Core Clock
993 MHz
CUDA Cores
384
Effective Memory Clock
1.782 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Interfaces Details
DVI-D , VGA , HDMI
API Supported
DirectX 11.1, OpenGL 4.4
3.4 cm x 17.9 cm x 11.1 cm
Microsoft Certification
Compatible with Windows 7
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
993 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, Dust-proof fan, GPU Tweak Streaming, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.782 GHz
Bus Width
128-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3.4 cm
17.9 cm
11.1 cm
