ASUS GT 730 silent and low profile graphics card with DirectX®11 and HDMI support
- Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers.
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played.
Graphics Engine: NVIDIA GeForce GT 730
- Bus Standard: PCI Express 2.0
- Video Memory: GDDR3 2GB
- Engine Clock: 902 MHz
- CUDA Core: 384
- Memory Clock: 900 MHz ( 1800 MHz GDDR3 )
- Memory Interface: 64-bit
- Resolution: DVI Max Resolution : 2560x1600
- Interface: D-Sub Output : Yes x 1 , DVI Output : Yes x 1 (DVI-D), HDMI Output : Yes x 1 , HDCP Support : Yes
- Software: ASUS GPU Tweak & Driver
- Dimensions: 5.4 " x 2.71 " x 1.18 " Inch / 13.7 x 6.9 x3 Centimeter
Graphics galore for everyone!
GT 730 is the fantastic graphics card from ASUS. Engineered with a highly-efficient 0dB thermal design, it dissipates heat in complete silence - making GT 730 the perfect choice for your slimline home-theater PC build. Advanced EMI shielding reduces electromagnetic interference for a stable signal, pin-sharp images and safer and healthier computing. -
Perfect for building a hushed HTPC
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GT730-SL-2GD3-BRK - graphics card - GF GT 730 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 730 - up to
- Memory
- 2 GB DDR3
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-D , VGA , HDMI
- API Supported
- DirectX 11
- Fanless
- 3 cm x 13.7 cm x 6.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - low profile - fanless
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- Native HDMI, ASUS 0-dB thermal solution, Nvidia PhysX-Ready, Super Alloy Power technology, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 64-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3 cm
- 13.7 cm
- 6.9 cm
