The ASUS GT 730 is the fantastic new graphics card from ASUS. Engineered with a highly-efficient 0 dB thermal design, it dissipates heat in complete silence - making GT 730 the perfect choice for your slimline home-theater PC (HTPC) build. Advanced EMI shielding reduces electromagnetic interference by up to 66% for a stable signal, pin-sharp images and safer and healthier computing.
Perfect for building a hushed HTPC
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers. -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors. -
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
- ASUS GT730-SL-1GD3-BRK - graphics card - GF GT 730 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 730
- Memory
- 1 GB GDDR3
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 1.8 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Interfaces Details
- DVI-D , VGA , HDMI
- API Supported
- DirectX 11
- Fanless
- 3 cm x 13.7 cm x 6.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 902 MHz
- CUDA Cores
- 384
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- Nvidia PhysX-Ready, Super Alloy Power technology, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
- Size
- 1 GB
- Technology
- GDDR3 SDRAM
- Effective Clock Speed
- 1.8 GHz
- Bus Width
- 64-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 3 cm
- 13.7 cm
- 6.9 cm
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
