Asus GeForce GT 710 EVO 2GB Graphics Card
Quicklinx: H9FFWS00 Mfr#: GT710-SL-2GD3-BRK-EVO
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GT 710, NVIDIA GeForce GT 710, NVIDIA GeForce GT 710
Interface: PCI Express 2.0
Memory Size: 2GB, 2GB
Digital Output: High-Definition Multimedia Interface (HDMI)
  • High-Definition Multimedia Interface (HDMI)
£41.03 ex VAT
£49.23 inc VAT
The ASUS GeForce GT 710 is a passively cooled graphics card that boosts user productivity on multi-display setups thanks to quieter operation.
  • Efficient memory technology
    With 2 GB of DDR3 SDRAM and a memory clock speed of 900 MHz, this graphics card delivers reliable performance for everyday applications while maintaining energy efficiency.
  • Enhanced multi-display capabilities
    Allows connectivity to up to 3 monitors simultaneously, enabling users to improve productivity through advanced multitasking on larger screens.
  • Flexible connectivity options
    Equipped with DVI-D, HDMI, and VGA output ports, it provides multiple options for connecting to various display types, ensuring compatibility with most monitors.
  • High resolution support
    Supports a maximum external resolution of 2560 x 1600, delivering clear and detailed visuals for both work and leisure.
  • Optimized for compact builds
    The low-profile design makes it suitable for small form factor cases, allowing for enhanced graphics capabilities without compromising space.
ASUS GeForce GT 710 EVO - graphics card - GF GT 710 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0
Graphics Engine
NVIDIA GeForce GT 710 - up to
2 GB DDR3
Core Clock
954 MHz
CUDA Cores
192
Effective Memory Clock
900 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
3
Interfaces Details
VGA , DVI-D , HDMI
API Supported
OpenGL 4.5
3.9 cm x 17 cm x 6.9 cm
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
954 MHz
CUDA Cores
192
Max Resolution
2560 x 1600
3
Interfaces Details
VGA , DVI-D , HDMI
API Supported
OpenGL 4.5
AUTO-EXTREME technology, Passive Cooling Solution
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
900 MHz
Bus Width
64-bit
Required Power Supply
300 W
Software Included
ASUS GPU Tweak III
3.9 cm
17 cm
6.9 cm
Memory Size: 2GB
Memory Size: 2GB
Brand: Asus
