The ASUS GeForce GT 710 is a passively cooled graphics card that boosts user productivity on multi-display setups thanks to quieter operation.
                Efficient memory technologyWith 2 GB of DDR3 SDRAM and a memory clock speed of 900 MHz, this graphics card delivers reliable performance for everyday applications while maintaining energy efficiency.
                Enhanced multi-display capabilitiesAllows connectivity to up to 3 monitors simultaneously, enabling users to improve productivity through advanced multitasking on larger screens.
                Flexible connectivity optionsEquipped with DVI-D, HDMI, and VGA output ports, it provides multiple options for connecting to various display types, ensuring compatibility with most monitors.
                High resolution supportSupports a maximum external resolution of 2560 x 1600, delivering clear and detailed visuals for both work and leisure.
                Optimized for compact buildsThe low-profile design makes it suitable for small form factor cases, allowing for enhanced graphics capabilities without compromising space.
- ASUS GeForce GT 710 EVO - graphics card - GF GT 710 - 2 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0
- Graphics Engine
- NVIDIA GeForce GT 710 - up to
- Memory
- 2 GB DDR3
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- Effective Memory Clock
- 900 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- Interfaces Details
- VGA , DVI-D , HDMI
- API Supported
- OpenGL 4.5
- 3.9 cm x 17 cm x 6.9 cm
- Bus Type
- PCI Express 2.0
- Graphics Engine
- Core Clock
- 954 MHz
- CUDA Cores
- 192
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- OpenGL 4.5
- AUTO-EXTREME technology, Passive Cooling Solution
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 900 MHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- Software Included
- ASUS GPU Tweak III
- 3.9 cm
- 17 cm
- 6.9 cm
