Asus GeForce GT 710 1GB DDR3 Dual-DVI-D HDMI DX12 Graphics Card
Quicklinx: BWDPWS00 Mfr#: 710-1-SL
Asus 710-1-SL
Auto-eXtreme technology for better Performance & Longevity!
ASUS exclusive Auto-eXtreme Technology is an industry-first, 100% automated production process that incorporates premium materials to set a new standard of graphics card quality, performance and longevity. Embedded with ASUS exclusive Super Alloy Power II, graphic cards can reach to 2.5 times product lifespan longer than traditional capacitors.
ASUS 710-1-SL comes with exclusive GPU Tweak utility, which allows users to modify clock speeds and voltages.
  • 0 dB silent cooling
    Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
  • AUTO-EXTREME technology with Super Alloy Power II
    ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
ASUS 710-1-SL - graphics card - GF GT 710 - 1 GB
Graphics card
Bus Type
PCI Express 2.0
Graphics Engine
NVIDIA GeForce GT 710 - up to
1 GB DDR3
Core Clock
954 MHz
CUDA Cores
192
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
OpenGL 4.4, DirectX 12
Fanless
2.7 cm x 13.5 cm x 12 cm
Graphics card - fanless
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
954 MHz
CUDA Cores
192
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
ASUS 0-dB thermal solution, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
1 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak II
2.7 cm
13.5 cm
12 cm
