PLEASE NOTE: These Graphics Cards Do NOT Ship With Low Profile Brackets From April 1st 2013
Premium alloys inside power delivery components defeat the heat for cards that run better, cooler, and longer than reference. Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. Support 4 HD displays with Nvidia Surround technology or to connect a 3D-enabled TV for a true cinematic Blu-ray 3D experience.
Super alloy power
Premium alloys inside power delivery components defeat the heat for cards that run better, cooler, and longer than reference. -
Dust-proof fan
Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance. -
NVIDIA CUDA
It unlocks the power of GPU's processor cores to accelerate the most demanding system tasks. -
NVIDIA PhysX
Dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters. -
4 HD displays support
Support 4 HD displays with Nvidia Surround technology or to connect a 3D-enabled TV for a true cinematic Blu-ray 3D experience. -
DirectX 11 done right
Brings new levels of visual realism to gaming on the PC and get top-notch performance.
- ASUS GT640-1GD3-L - graphics card - GF GT 640 - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GT 640
- Memory
- 1 GB DDR3
- Core Clock
- 901 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 1.782 GHz
- Shader Clock
- 1802 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 4
- DVI-D (dual link) , VGA , HDMI
- API Supported
- DirectX 11, OpenGL 4.2
- 17.1 cm x 12.1 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 901 MHz
- CUDA Cores
- 384
- Shader Clock
- 1802 MHz
- Max Resolution
- 2560 x 1600
- 4
- API Supported
- Nvidia CUDA technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Super Alloy Power technology, Dust-proof fan, HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.782 GHz
- Bus Width
- 128-bit
- Software Included
- Drivers & Utilities, ASUS GPU Tweak
- 17.1 cm
- 12.1 cm
