Asus GeForce GT 620 700MHz 2GB PCI E 2.0 HDMI DirectCU Silent
Quicklinx: 8PW2WS00 Mfr#: GT620-DCSL-2GD3
  • High-Definition Multimedia Interface (HDMI)
Marketing description is not available.
  • Passive 0dB efficient cooling
    DirectCU Silent cooling design utilizes direct contact copper heatpipes and a large heatsink surface to speed up heat dissipation without any noise produced - achieving16% cooler performance than conventional passive cards.Super Alloy Power
  • Enhanced durability and cooling
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
ASUS GT620-DCSL-2GD3 - graphics card - GF GT 620 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA GeForce GT 620
2 GB DDR3
Core Clock
700 MHz
CUDA Cores
96
Effective Memory Clock
1.82 GHz
Shader Clock
1400 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
DVI-I (dual link) , VGA , HDMI
API Supported
DirectX 11
Fanless
1.52 cm x 18.79 cm x 11.17 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - fanless
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
700 MHz
CUDA Cores
96
Shader Clock
1400 MHz
Max Resolution
2560 x 1600
API Supported
DirectX 11
ASUS 0-dB thermal solution, heatpipe cooling, Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, ASUS DirectCU Silent Technology, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.82 GHz
Bus Width
64-bit
75 Watt
Software Included
ASUS GPU Tweak
1.52 cm
18.79 cm
11.17 cm
