Asus GeForce GT 1030 OC 2GB GDDR5 PCIe 3.0 Graphics Card
Quicklinx: CWYBWS00 Mfr#: PH-GT1030-O2G
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GT 1030
Interface: PCI Express 3.0 x16
Memory Size: 2GB, 2GB
30 in stock
£73.82 ex VAT
£88.58 inc VAT
ASUS Phoenix GeForceĀ® GT 1030 OC edition 2GB GDDR5 is the best for compact PC build and home entertainment
  • 1531 MHz Boost Clock in OC mode for outstanding performance and gaming experience.
  • Dual-ball Bearing Fan reduces spinning friction for 2 times longer lifespan and cooling efficiency.
  • IP5X-Certified Fan is dust resistant for longer fan lifespan.
  • Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
  • GPU Tweak II makes performance tweaking easier and more visual than ever with an intuitive, all-new UI.
  • Dust resistance
    ASUS fan design is dust resistant for improved reliability and optimal fan performance, even under severe conditions.
  • Longer lifespan
    Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS GT 1030 lasts longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Auto-Extreme technology with Super Alloy Power II
    ASUS graphics cards are produced using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
ASUS PH-GT1030-O2G - OC Edition - graphics card - GF GT 1030 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1278 MHz
Boost Clock
1531 MHz
CUDA Cores
384
Effective Memory Clock
6.008 GHz
Memory Interface
64-bit
Max Resolution
1920 x 1200
DVI-D (dual link) , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.6 cm x 18.4 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1278 MHz
Boost Clock
1531 MHz
CUDA Cores
384
Max Resolution
1920 x 1200
API Supported
Nvidia PhysX-Ready, Adaptive V-Sync, Dual ball Bearing Fan, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
64-bit
Software Included
Display drivers, ASUS GPU Tweak II
IP5X
3.6 cm
18.4 cm
11.1 cm
Memory Size: 2GB
Memory Size: 2GB
Brand: Asus
Price Range Ex VAT: 50 - 100
