Asus F2A55-M LK2 PLUS AMD A55 FM2 DDR3 mATX
Quicklinx: 8PWNWS00 Mfr#: F2A55-M LK2 PLUS
This motherboard supports AMD A-series Accelerated Processor with AMD Radeon HD series graphic. This revolutionary APU (Accelerated Processing Unit) combines processing power and advanced DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and an industry-leading visual experience. It features Dual-channel DDR3 memory support and accelerates data transfer rate up to 5 GT/s.
ASUS motherboards using the AMD A55 chipset employ precise digital voltage regulation for the APU, called DIGI+ VRM (Voltage Regulation Modules) digital power design. The APU voltage is adjusted via either carefully developed automated modes, or by using user-defined profiles. The effect is that DIGI+ VRM technology ensures greater energy efficiency and the most precise power delivery. Boosted by world-renowned ASUS quality, it creates an ideal computing platform for a diverse range of applications, from gaming to multimedia or office work and heavy multitasking. Engineered and tested to assure unmitigated performance, ASUS A55 boards with DIGI+ VRM remain efficient and accurate, for reliable application in every scenario.
  • AMD A-series accelerated processor with AMD Radeon HD series graphic
  • AMD A55 FCH (Hudson D2)
    AMD A55 FCH (Hudson D2) is designed to support up to 5GT/s interface speed and PCI Express 2.0 x 16 graphics. It natively supports 6 x SATA3 Gb/s ports.
  • DIGI+ power control: digital power design for the APU
  • Faster USB 3.0 transmission with UASP
    ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol), the USB 3.0 standard. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. ASUS software automatically accelerates data speeds for compatible USB 3.0 peripherals without the need for any user interaction.
  • One stop access to innovative ASUS features
    With its user-friendly interface, ASUS AI Suite II consolidates all the exclusive ASUS features into one simple to use software package. It allows users to supervise over-clocking, energy management, fan speed control, voltage and sensor readings. This all-in-one software offers diverse and ease to use functions, with no need to switch back and forth between different utilities.
  • Real-time network bandwidth control
    With a single-click on/off button, the application currently in use has its data and network bandwidth prioritized over other programs. Moreover, you can prioritize your favorite software easily by configuring profiles through the intuitive user interface. Within the profile, programs can be pre-scheduled to run in a specific time period to avoid network congestion and long-waits on downloads. Auto PPPoE network connection provides a one-step setup for enhanced online convenience. Overall, it's an intuitive network bandwidth control center.
  • Go to the limit with iGPU level up
    GPU Boost accelerates the integrated GPU for extreme graphics performance. The user-friendly interface facilitates flexible frequency adjustments. It easily delivers stable system-level upgrades for every use.
  • Fan Xpert
    ASUS fan Xpert intelligently allows you to adjust the CPU and chassis fan speeds according to different ambient temperatures caused by different climate conditions in different geographic regions and your PC's loading. The built-in variety of useful profiles offers flexible controls of fan speed to achieve a quiet and cool environment.
  • EPU
    Tap into the world's first real time PC power saving engine through a simple onboard switch or AI Suite II utility. Get total system power savings by automatically detecting current PC loadings and intelligently moderating power consumption. This also reduces fan noise and extends component longevity.
  • Double USB access, double convenience
    Experience ultra-fast data transfer at 4.8 Gbps with USB 3.0 - the connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10x faster and is also backward compatible with USB 2.0 components.
  • Flexible and easy BIOS interface
    ASUS UEFI BIOS offers the first mouse-controlled graphical BIOS designed with selectable modes, providing a user-friendly interface that goes beyond traditional keyboard-only controls. It also natively supports fully-utilized hard drives larger than 2.2 TB in 64-bit operating systems.
  • ASUS exclusive interface
    EZ mode displays frequently-accessed info. Users can choose system performance settings and drag and drop boot priorities. Advanced mode for performance enthusiasts includes detailed DRAM settings via a dedicated memory info page for complete insight.
ASUS F2A55-M LK2 PLUS - motherboard - micro ATX - Socket FM2 - AMD A55
Motherboard - micro ATX
Chipset Type
AMD A55
Processor Socket
1 x Socket FM2
Compatible Processors
Athlon, A series (supports CPUs with up to 4 cores)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
4 x SATA-300 (RAID)
USB / FireWire Ports
4 x USB 2.0 + (4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
AMD A55
Processor Socket
Socket FM2
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, AMD Memory Profile (AMP)
Audio
Audio Codec
Realtek ALC887-VD
High Definition Audio
LAN
Network Controller
Realtek RTL8111F
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI , 2 x DIMM 240-pin
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x VGA , 1 x DVI-D , 1 x PS/2 mouse , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
4 x USB 2.0 , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Features
ASUS Anti-Surge Protection, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS DIGI+ VRM, AMD Radeon Dual Graphics, Conductive Polymer Capacitors, ASUS Network iControl, AMD Turbo CORE 3.0 technology, 3+2 Phase Power Design, AMD Memory Profile (AMP) support
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite II, ASUS Update
Plug and Play, RoHS, ACPI 2.0a, ErP Ready
22.6 cm
17.8 cm
