AMD A-series accelerated processor with AMD Radeon HD 7000 series graphicsThis motherboard supports AMD A-series accelerated processor with AMD Radeon HD 7000 series graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and visual experience. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5 Gtps.
AMD A55 FCH (Hudson D2) is designed to support up to 5 Gtps interface speed and 6 x SATA 3.0 Gbps. F2A55 brings you the multi-GPU choice of CrossFireX. Expect a gaming style you've never experienced before!
This motherboard supports AMD A-series accelerated processor with AMD Radeon HD 7000 series graphics. This revolutionary APU (Accelerated Processing Unit) combines processing power and DirectX 11 graphics in one small, energy-efficient design to enable accelerated performance and visual experience. It features dual-channel DDR3 memory support and accelerates data transfer rate up to 5 Gtps. -
AMD A55 FCH (Hudson D2) is designed to support up to 5 Gtps interface speed and 6 x SATA 3.0 Gbps. -
Quad-GPU CrossFireX support
F2A55 brings you the multi-GPU choice of CrossFireX. Expect a gaming style you've never experienced before! -
DIGI+ power control: digital power design for the APU
ASUS motherboards using the AMD A55 chipset employ precise digital voltage regulation for the APU, called DIGI+ VRM (Voltage Regulation Modules) digital power design. The APU voltage and VRM frequency are adjusted via either carefully developed automated modes, or by using user-defined profiles. The effect is that DIGI+ VRM technology ensures greater energy efficiency and the most precise power delivery. -
USB 3.0 Boost
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol), the USB 3.0 standard. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. -
Network iControl
With a single-click on/off button, the application currently in use has its data and network bandwidth prioritized over other programs. Moreover, you can prioritize your favorite software easily by configuring profiles through the intuitive user interface. Within the profile, programs can be pre-scheduled to run in a specific time period to avoid network congestion and long-waits on downloads. -
AI Suite II
With its user-friendly interface, ASUS AI Suite II consolidates all the exclusive ASUS features into one simple to use software package. It allows users to supervise overclocking, energy management, fan speed control, voltage and sensor readings. This all-in-one software offers diverse and ease to use functions, with no need to switch back and forth between different utilities. -
ASUS Anti-Surge Protection
Anti-Surge Protection design detects overvoltage conditions and prevents voltage surges from spreading in real time. It also actively cuts off the overvoltage supply to protect the system. -
ESD
Protect your computer with ESD guards. Electrostatic discharge (ESD) conditions can happen while plugging or unplugging any USB peripherals-causing damage to the computer. ASUS ESD guards clamp the ESD voltage and shunt the majority of the ESD current away for a more reliable computing environment. -
UEFI BIOS (EZ mode)
Flexible and easy BIOS interface ASUS UEFI BIOS offers the first mouse-controlled graphical BIOS designed with selectable modes, providing a user-friendly interface that goes beyond traditional keyboard-only controls. It also natively supports fully-utilized hard drives larger than 2.2 TB in 64-bit operating systems. -
ASUS exclusive interface
EZ Mode displays frequently-accessed infomation. Users can choose system performance settings and drag and drop boot priorities. Advanced Mode for performance enthusiasts includes detailed DRAM settings via a dedicated memory info page for complete insight. -
TurboV
Feel the adrenaline rush of real-time OC-now a reality with the ASUS TurboV. This easy OC tool allows you to overclock without exiting or rebooting the OS; and its user-friendly interface makes overclock with just a few clicks away. -
GreenASUS and ErP ready
The motherboard is European Union's Energy-related Products (ErP) ready, and ErP requires products to meet certain energy efficiency requirements in regards to energy consumptions. This is in line with ASUS vision of creating environment-friendly and energy-efficient products through product design and innovation to reduce carbon footprint of the product and thus mitigate environmental impacts.
- ASUS F2A55 - motherboard - ATX - Socket FM2 - AMD A55
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD A55
- Processor Socket
- 1 x Socket FM2
- Compatible Processors
- Athlon II X4, A8 series, A6 series, A4 series, A10 series (supports CPUs with up to 4 cores)
- Data Bus Transfer Rate
- 5 GT/s
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-300 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 6 x USB 2.0 + (6 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2048 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD A55
- 5 GT/s
- Processor Socket
- Socket FM2
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR3
- Bus Clock
- 2400 MHz, 2200 MHz, 2000 MHz, 1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2250 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, AMD Memory Profile (AMP)
Graphics
- 2048 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111F
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 3 x PCI , 4 x DIMM 240-pin
- Storage Interfaces
- SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x TOSLINK , 2 x USB 3.0 , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
- Internal Interfaces
- 6 x USB 2.0 , 1 x SPDIF out - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, ASUS EFI BIOS, UEFI BIOS
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS TurboV, ASUS DIGI+ VRM, Fanless Design Heatsink, AMD Radeon Dual Graphics, ASUS Protect 3.0 Technology, Conductive Polymer Capacitors, ASUS Fan Xpert+, ASUS USB 3.0 Boost technology, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, ASUS Network iControl, Low EMI Solution, Disk Unlocker, AMD Turbo CORE 3.0 technology
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
- Plug and Play, ACPI 2.0a, ErP Ready
- 30.5 cm
- 22.4 cm
- Limited warranty - 3 years
Asus F2A55 AMD FM2 A55 DDR3 ATX
