Asus ExpertCenter E5 AiO Intel Core i5-11500B 8GB 256GB SSD 21.5" Windows 11 Professional 64-bit
Quicklinx: HC7FWS00 Mfr#: E5202WHAK-BA064X
  • Core i5
  • IEEE 802.11n
Featuring the powerful desktop processor, high-speed connectivity, two-way AI noise cancelation for clear conferencing, upgradeable storage, VESA mount compatibility, Modern Standby efficiency and enterprise-grade privacy security features, ExpertCenter E5 AiO is the no-compromise solution for forward-thinking businesses.
  • Built to perform
    Built to perform and easy to manage for enterprises, ASUS ExpertCenter E5 AiO 22 powers through any task - saving time and minimizing admin. It packs serious business horsepower with a powerful processor, generous 8 GB DDR4 memory and comprehensive connectivity, including the Thunderbolt 4.0. Its sleek, ultra-compact form also supports dual-SSD RAID and high-speed Wi-Fi 6E connectivity, so it's ready to serve your business today and long into the future.
  • Powerfully immersive sound without distraction
    To level up professional conferencing, ASUS ExpertCenter E5 AiO 22 also benefits from AI-powered two-way noise-canceling technology that employs sophisticated machine-learning techniques. The technology includes both an upstream function to filter noise around the speaker, and a downstream function to eliminate noise from the person at the other end of the conversation. This helps ensure clear communication in almost any scenario. To simplify use, shortcut keys to make it easy to enable the technology or mute the microphone.
  • Quick controls for better productivity
    To help remote working and video conferencing, the engineers have added some dedicated shortcut keys to ASUS ExpertCenter E5 AiO 22's keyboard. Now, controls such as muting the microphone, disabling noise cancelation and more besides are just a quick touch away - so you can stay productive at all times.
  • Maintenance made simpler
    The base can be quickly and easily removed to allow fast access to the RAM, hard drive and storage, enabling these components to be upgraded or replaced without dismantling the entire machine.
  • Find the perfect viewing position
    The ergonomic stand on ASUS ExpertCenter E5 AiO 22 enables tilt, swivel and height adjustments for perfect viewing positions. It gives you the freedom to use your display at any angle, so whether sitting at a desk or standing to serve customers, you'll always have the best view. It will also rotate 180° horizontally and 90° vertically, so you can switch from front to rear camera mode and keep video conferences moving along.
ASUS ExpertCenter E5 AiO 22 E5202WHAK BA064X - all-in-one Core i5 11500B 3.3 GHz - 8 GB - SSD 256 GB - LED 21.5"
Personal computer - all-in-one
Intel Core i5 (11th Gen) 11500B / 3.3 GHz (up to 4.6 GHz, (6-core)
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 256 GB - PCI Express 3.0 - M.2 - NVM Express (NVMe)
Optical Storage
No optical drive
Card Reader
3 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) @ 60 Hz - 16:9
Graphics Controller
Intel UHD Graphics
Camera
1GbE, 802.11a, Wi-Fi 5, 802.11b/g/n, Bluetooth 5.1
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
Microsoft 365 (1 month trial), MyASUS, ASUS Business Manager, McAfee
49 cm x 20.1 cm x 41.1 cm
7.7 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel HM570
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
8 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots
2 (Total)
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express 3.0
NVM Express (NVMe)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
Memory Stick, MultiMediaCard, SD Memory Card
Monitor
Monitor Type
LED
Diagonal Size
21.5"
Native Resolution
V-Sync Rate at Max Res.
60 Hz
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
100% sRGB
Response Time
14 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
84% screen-to-body ratio, WideView, anti-glare, tilt stand (-5°- 15°)
Graphics Controller
Graphics Processor
Intel UHD Graphics
Video Interfaces
HDMI, DisplayPort
Camera
Camera
Resolution
720p
Privacy shutter
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Optical
Audio Input
Array microphone
Ethernet Controller
Realtek RTL8111H
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 5.1
Dual stream (2x2)
Slots
2 (total) / 1 (free) x M.2 Card - 2280
3 x USB 3.2 Gen 1 , 1 x USB-C 3.2 Gen 2 , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x HDMI output , 1 x DisplayPort
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
AC 100-240 V (50/60 Hz)
Power Provided
150 Watt
Operating System / Software
OS Provided
Windows 11 Pro
Software
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
49 cm
20.1 cm
41.1 cm
7.7 kg
