ASUS ExpertBook P1 P1511 Intel Core i3 1115G4 15.6" 8GB 256GB Windows 10 Pro Slate Grey
Quicklinx: GVF5WS00 Mfr#: P1511CEA-BQ1261R
  • Core i3
  • IEEE 802.11n
Whether for work or play, ASUS ExpertBook P1 is the entry-level laptop that delivers powerful performance and immersive visuals. Its NanoEdge display boasts wide 178° viewing angles and a matte anti-glare coating for a truly engaging experience.
  • Fast and efficient
    With powerful processors, ExpertBook P1 helps you get things done swiftly and efficiently.
  • Constantly connected
    ExpertBook P1 is equipped with the reversible USB-C 3.2 port, featuring any-way-up design that makes connecting devices as easy as possible. It also delivers faster data transfer speeds faster! There are USB 3.2 and USB 2.0 ports, HDMI output, and a microSD card reader - so you can easily connect all your current peripherals, displays and projectors with zero hassle.
  • NanoEdge display: get a wider view of the world
    The NanoEdge display gives ExpertBook P1 a vast screen area for an immersive viewing experience for work and play. Its wide-view panel features an anti-glare coating to reduce unwanted distractions from irritating glare and reflections, so you can truly focus on what's in front of you.
  • Safe fast-charging and long-lasting battery
    ExpertBook P1 features 3x the lifespan of standard lithium-ion batteries. With ASUS fast-charge technology, a low battery can be charged to 60 percent in just 49 minutes.
  • Rich, crystal-clear audio
    ASUS SonicMaster is a combination of hardware, software and audio tuning designed with the goal of giving you the very best audio experience. A professional-grade codec ensures precise audio encoding and decoding, while amplifiers, large speakers and resonance chambers perfectly suited to ExpertBook P1 ensure a powerful audio delivery and deeper bass. Additional signal processing and tuning help refine minute details filter noise and improve audio clarity so you get truly immersive sound.
ASUS ExpertBook P1 P1511CEA-BQ1261R - 15.6" - Intel Core i3 - 1115G4 - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro
Intel Core i3 (11th Gen) - 1115G4 / 3 GHz, up to 4.1 GHz / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
2-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip, fingerprint reader
Slate grey
36 cm x 23.5 cm x 1.99 cm
1.8 kg
Repairability Index
6.2 (out of 10)
Notebook
Operating System
Windows 10 Pro
Processor / Chipset
CPU
Intel Core i3 (11th Gen) 1115G4 / 3 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
Dual-Core
Cache
6 MB
RAM
8 GB (provided memory is soldered)
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe 3.0 x4 - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, IPS-level
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - VGA
Sound
Speaker, microphone
Input
Keyboard, touchpad
Numeric Keypad
Chiclet keyboard
Communications
Wireless
Network Interface
Gigabit Ethernet
2-cell Lithium Ion
37 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 , USB-C 3.2 Gen 1 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN (on supplied adapter)
Slate grey
Case Material
Plastic
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.8 kg
Sustainability Information
Repairability Index
6.2 (out of 10)
TCO Certified
