Asus ExpertBook B1 Intel Core i7-1255U 16GB 512GB SSD 15.6" Windows 11 Professional 64-bit
Quicklinx: HC74WS00 Mfr#: B1502CBA-BQi715X
  • Core i7
  • IEEE 802.11n
Introducing the ASUS ExpertBook B1
Primed to perform. Configured for your business. Packed with business-friendly features and power, ASUS ExpertBook B1 is the ideal choice for ambitious firms and inspirational educational institutions. With a compact design, a bright, clear 15.6-inch display for vibrant visuals, plus impressive performance, enterprise-level security, military-grade durability, and extensive connectivity, ExpertBook B1 is the perfect portable partner to empower your business.
  • Enhanced durability
    Built to withstand the rigors of daily use, the ASUS ExpertBook B1 has been MIL-STD-810H tested, ensuring it can handle the bumps and drops of everyday life. Its case is crafted from durable plastic, designed to protect against the elements and keep your device safe and secure.
  • Optimal performance
    At the heart of the ASUS ExpertBook B1 lies a 12th Generation Intel Core i7 processor, capable of reaching speeds up to 4.7 GHz with Intel Smart Cache technology. Combined with 16 GB of DDR4 SDRAM, this notebook delivers seamless multitasking and smooth performance for all your computing needs.
  • Vivid visuals
    Experience stunning clarity and color accuracy on a 15.6-inch Full HD LED display, boasting a 45% NTSC color gamut and anti-glare technology. With an image brightness of 250 cd/m2 and an 83% screen-to-body ratio, the ASUS ExpertBook B1 offers immersive viewing for work and entertainment.
  • Robust connectivity
    Stay connected with a comprehensive suite of interfaces, including USB-C 3.2 Gen 2/DisplayPort for high-speed data transfer and HDMI for connecting to external displays. With dual-band Wi-Fi 6E and Bluetooth 5.3, the ASUS ExpertBook B1 ensures you're always connected to high-speed Internet and your Bluetooth devices.
  • Secure and convenient
    The ASUS ExpertBook B1 prioritizes your security with features like a fingerprint reader and Trusted Platform Module (TPM 2.0) security chip. A privacy shutter for the IR camera, along with Windows Hello, offers peace of mind and convenient, secure logins.
ASUS ExpertBook B1 B1502CBA-BQI715X - 15.6" - Intel Core i7 - 1255U - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 11 Pro
Intel Core i7 (12th Gen) - 1255U / 1.7 GHz, up to 4.7 GHz / 12 MB Cache
16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
Storage
512 GB SSD - NVMe
Display
15.6" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Star black
36.16 cm x 23.3 cm x 1.99 cm
1.69 kg
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Gold
Notebook
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 1255U / 1.7 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
10-core
Cache
12 MB
Intel Smart Cache
RAM
16 GB (1 x 8 GB + 8 GB (soldered))
Max RAM Supported
48 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
15.6"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, 83% screen-to-body ratio
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Camera Features
Privacy shutter, IR camera, Windows Hello
Sound
Dual speakers, array microphone
Audio Features
Output: Audio by Dirac
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Spill-resistant, chiclet keyboard, 1.4mm travel distance
Communications
Wireless
Network Interface
Gigabit Ethernet
Dual stream (2x2)
3-cell Lithium Ion
42 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 20 V, 3.25 A
Connections & Expansion
Interfaces Details
USB 2.0 , USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (Power Delivery) , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI , LAN
Star black
Case Material
Plastic
Security
MIL-STD-810H tested, BIOS protection, Computrace ready from BIOS
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter
RoHS, REACH, FSC Mix
1.69 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
