Asus Eee PC 1015P Seashell Atom N450 10.1" 1GB 160GB W7S White
Quicklinx: 730LWS00 Mfr#: 1015P-WHI043S
  • Atom
  • IEEE 802.11n
  • Microsoft Windows 7 Starter
Go anywhere in style with Eee PC™ 1015P Seashell
  • Genuine Windows® 7 Starter
  • Elegantly Beautiful Seashell-inspired Design
  • Enjoy long-day-computing with 11 hours* battery life
  • Easy Mobile Connectivity with built-in 802.11n
  • Comfortable using experience with extremely large touch pad and ergonomically Chiclet Keyboard
Designed to Keep You on the Move
With a design ethos that stems from the thin and light Eee PC™ tradition, the Eee PC™ Seashell 1015P has taken it a step further, featuring more rounded curves to give it a more streamlined shape. Add to that a contrasting play on light and shadows, and a variety of colors; the 1015P has come into its own indeed.
Ideal for the traveler, the Eee PC™ Seashell 1015P's light and compact weight means that it will easily fit into your hand luggage. The 1015P is the backpacker's companion, accompanying you to adventures in foreign lands. And with cloud computing access, you'll be able to access your movie or music files online, or surf the net to update your blog to tell the world of your travels. The 1015P ensures you won't be bored while on transit at the airport.
Saves Power and the Planet - 11 hours battery life with Super Hybrid Engine
The Eee PC™ Seashell 1015P answers consumers' needs for a netbook that boasts a stylish design with a long battery life. The 1015P has a 11 hour battery life* thanks to the ASUS-exclusive Super Hybrid Engine technology. The SHE intelligently adapts and adjusts power settings to give you the CPU performance you need. Based on the user settings and the applications being run, the SHE tailors the appropriate power requirements for the task at hand to ensure maximum efficiency.
Ergonomically Designed for You
The Eee PC™ Seashell 1015P boasts a streamlined and aerodynamic design with strongly defined contours. ASUS' approach to material innovation means that your 1015P will be available with patterned finish.
It features an ergonomically designed chiclet keyboard and a 10.1"LED backlit WSVGA screen (1024x600) to ensure user comfort even after prolonged use.
Cloud computing: Imagine, Access, and Do More with ASUS' Cloud Computing Service Eee Docking
Every Eee PC 1015P comes with the ASUS-exclusive Eee Docking platform that serves as a convenient, one-stop solution that grants you easy access to digital content, services, and other useful software.
  • Access lets you stream or download a wide variety of exciting digital contents. It includes ASUS @Vibe, Game Park and the ASUS AP Bank.
  • Sharing lets you easier to keep all your photos, music, videos, documents, bookmarks, and more in sync and up to date across all your computers. It includes E-Cam** and Syncables.
  • Xperience features a host of applications that enhance your Eee PC's audio visual performance. It includes Splendid.
  • Tools features a suite of useful tools such as Live update, Font resizer, LocaleMe**, Docking seeting that enhance your Eee PC user experience
  • Designed to keep you on the move
    With a design ethos that stems from the thin and light Eee PC tradition, the Eee PC Seashell 1015P has taken it a step further, featuring more rounded curves to give it a more streamlined shape. Add to that a contrasting play on light and shadows; the 1015P has come into its own indeed.
  • Saves power and the planet with super hybrid engine
    The Eee PC Seashell 1015P answers consumers' needs for a netbook that boasts a stylish design with a long battery life. The SHE intelligently adapts and adjusts power settings to give you the CPU performance you need. Based on the user settings and the applications being run, the SHE tailors the appropriate power requirements for the task at hand to ensure maximum efficiency.
  • Ergonomically designed for you
    The Eee PC Seashell 1015P boasts a streamlined and aerodynamic design with strongly defined contours. ASUS' approach to material innovation means that your 1015P will be available with patterned finish. It features an ergonomically designed chiclet keyboard and a 10.1" LED backlit WSVGA screen (1024 x 600) to ensure user comfort even after prolonged use.
ASUS Eee PC 1015P Seashell - 10.1" - Intel Atom - N450 - 1 GB RAM - 160 GB HDD
Netbook
Operating System
Windows 7 Starter
Intel Atom N450 / 1.66 GHz / 512 KB Cache
1 GB DDR2
Storage
160 GB HDD
Display
10.1" LED backlight 1024 x 600 / WSVGA
Graphics
Intel GMA 3150
Integrated Webcam
802.11b/g/n
6-cell
White
26.2 cm x 17.8 cm x 3.6 cm
1.1 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Limited warranty - 1 year
Netbook
Operating System
Processor / Chipset
CPU
Cache
512 KB
64-bit Computing
RAM
1 GB
Max RAM Supported
2 GB
DDR2 SDRAM
SO-DIMM 200-pin
Storage
Main Storage
160 GB HDD
Display
10.1"
LCD Backlight Technology
LED backlight
Resolution
1024 x 600 (WSVGA)
Widescreen
Audio & Video
Graphics Processor
Intel GMA 3150
Memory Allocation Technology
Dynamic Video Memory Technology 4.0
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
802.11b/g/n
6-cell Lithium Ion
Connections & Expansion
Interfaces Details
3 x USB 2.0 , VGA , Headphone output , Microphone input , LAN
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card)
Software
Software Included
ASUS Super Hybrid Engine, ASUS Eee Docking
White
1.1 kg
