ASUS proudly presents EA-AC87, the 4x4 Wireless-AC1800 2-in-1 media bridge and access point, featuring incredible faster-than-wired performance, enhanced coverage by 4-transmit, 4-receive antenna and MU-MIMO technology for multi-device performance, all in a stunningly designed device.
EA-AC87 is a super easy and convenient way to supercharge your existing wireless network and let your Ethernet devices to wireless!
World’s fastest 5 GHz data rate of 1734 Mbps for smooth 4K video playback and lag-free PC, Xbox One and PlayStation®4 online gaming.
4x4 MIMO design with AiRadar universal beamforming for unrivaled multi-device performance and wireless signal coverage up to 465 m2(around 5,000 ft2)1.
Media Bridge mode connects any wired device to a wireless network.
Access Point mode upgrades old routers to the latest-generation 5 GHz Wi-Fi.
5 GHz signal-quality indicators.
Great wireless performance
The multi-user MU-MIMO technology means that in Access Point mode, EA-AC87 can connect to multiple compatible clients simultaneously at each device's maximum speed. This means that as you connect more devices to EA-AC87, its performance actually improves, giving all users the great Internet experience. -
Excellent signal coverage
Boasting a powerful four-transmit, four-receive antenna design, EA-AC87 Access Point mode gives you an excellent wireless coverage, making it the ideal choice for large homes and multi-floor buildings. Even better, ASUS AiRadar intelligently strengthens wireless connectivity using 802.11ac universal beamforming technology, high-power amplification and ASUS RF fine-tuning. -
Media bridge mode
EA-AC87 is compatible with any Ethernet-enabled device, including smart TVs, multimedia players, game consoles and PCs. -
Access Point mode
EA-AC87 can add a fast and stable network to a single band router, upgrading it for smooth online gaming, 4K video streaming and speedier downloading. -
Signal-quality indicators
In media bridge mode, LEDs on the front of the EA-AC87 show the signal quality at a glance, so you can adjust the location of the router or EA-AC87 easily to get Wi-Fi reception.
- ASUS EA-AC87 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 5 GHz
- OS Required
- Linux, Apple MacOS X 10.1, Apple MacOS X 10.4 - 10.8, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- 16 cm x 16 cm x 4 cm
- 480 g
- 16 cm
- 16 cm
- 4 cm
- 480 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1734 Mbps
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
- Frequency Band
- 5 GHz
- Status Indicators
- Power, signal strength, LAN
- Access Point operational mode, firmware upgradable, Wi-Fi Protected Setup (WPS), wireless bridge mode, reset button, 4T4R MIMO technology, ASUS AiRadar, MU-MIMO technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- Wi-Fi CERTIFIED, IEEE 802.11ac
Aerial
- Antenna
- External detachable and internal
- Antenna Qty
- 8
- 5 x 1000Base-T - RJ-45
- C-Tick, FCC, NCC
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
