Be the winner on the battlefield with E3 Pro Gaming V5's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. SupremeFX's superior components maximize acoustic performance and eliminate interference - so you hear only the ultimate from your gaming headset or speakers! Banish analog interference and enjoy eye-catching, customizable lighting effects.
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill. Only the extremely quick shot survive, so E3 Pro Gaming V5 banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the exceptional networking technology, including tournament-level Gigabit Ethernet and LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall. Featuring the advanced Ethernet for faster, smoother gaming - anytime. The LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
Flawless audio that makes you part of the game
Be the winner on the battlefield with E3 Pro Gaming V5's truly immersive SupremeFX audio and experience sound so alive with realism that it hands you the vital competitive edge needed to win. With near-lossless delivery and Sonic Radar II technology to pinpoint battlefield enemies before they spot you, SupremeFX sounds stupendous - and puts both your ears and frags in front of everyone else! -
SupremeFX - shielded audio, superior sound
SupremeFX technology delivers high-fidelity, near-lossless audio no matter how frantic your game becomes. The purity and stability of the remarkable signal-to-noise ratio (SNR) is assured, with a shielded design, electromagnetic-interference (EMI) cover and voltage-protected power supply. SupremeFX's superior components maximize acoustic performance and eliminate interference - so you hear only the ultimate from your gaming headset or speakers! -
Illuminated shielding
Banish analog interference and enjoy eye-catching, customizable lighting effects. -
Premium audio capacitors
Fine-quality components that produce a warmer, natural sound with exceptional clarity and fidelity. -
Scan and detect to dominate
Sonic Radar II displays a stealthy overlay that shows what your opponents and teammates are up to on the battlefield, all managed via a simple control panel and customizable game list. See the direction and origin of key in-game sounds, and practice your enemy-pinpointing skill. -
Top-speed protected networking
Only the extremely quick shot survive, so E3 Pro Gaming V5 banishes lag - letting you annihilate your foes as fast as your trigger finger! The engineers pack in only the exceptional networking technology, including tournament-level Gigabit Ethernet and LANGuard and GameFirst technologies to keep your connection fast, so always fire first and watch your enemies fall. -
Gigabit Ethernet
Featuring the advanced Ethernet for faster, smoother gaming - anytime. The LAN has the serious double advantage of reducing CPU overhead and offering exceptionally high TCP and UDP throughput. This significantly reduces the processor's workload, so there's more power for your game and your gameplay. -
Pumped-up throughput - optimum surge protection
LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors for rock-solid gaming connections and better throughout for online play, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. -
Gamer's guardian for real-world protection
Protect your back in the game and let E3 Pro Gaming V5 protect all sides in the real world. Motherboard self-protection with loads of brilliant defenses, including the unique smart DIY features ensures long-term gaming is in your future. -
Built for gaming
E3 Pro Gaming V5 is built for play, shaped by professional gamers - strong enough storm through the industry's punishing labs workouts. With E3 Pro Gaming V5 you do more than just play - you'll experience gaming on the edge of reality. -
Audio connector
Capacitor protection on both front and back audio-output circuits. -
LAN connector
ESD TVS diode protection and an anti-surge LAN connector protects against extreme events, such as lightning strikes.
- ASUS E3 PRO GAMING V5 - motherboard - ATX - LGA1151 Socket - C232
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C232
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 v5 series
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel C232
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- SupremeFX
LAN
- Network Controller
- Intel I219LM
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCIe 3.0 x1 (auto turn-off if all PCI Express 3.0 x4 slots are occupied) , 2 x PCI
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2 - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Rapid Storage Technology
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 1 x USB-C , 4 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, GameFirst, ESD Guards, Q-DIMM, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, Sonic Radar II, USB 3.1 Boost, ASUS Gamer's Guardian
- Included Accessories
- Cable ties, cable labels, 1 x M.2 screw, I/O back cover
- Cables Included
- 4 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger+, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS RAMCache
- Plug and Play
- 30.5 cm
- 24.4 cm
Asus E3 PRO GAMING V5 Intel C232 S1151 DDR4 M.2 USB3.1 ATX
