The ASUS Dual Radeon RX 7800 XT 16GB OC Edition redefines gaming with its impressive specifications and features. Designed for gamers and professionals alike, this graphics card boasts a robust 16 GB GDDR6 memory and a high-speed 256-bit memory interface, making it capable of handling demanding games and applications with ease. With support for up to 4 monitors and compliance with the DisplayPort 2.1 and HDCP 2.3 standards, it offers versatility and future-proofing.
In addition to its performance, the Dual Radeon RX 7800 XT 16GB features an array of technologies, including AMD FidelityFX Super Resolution 2 for enhanced visual fidelity, AMD Noise Suppression for quieter operation, and the RDNA 3 Gaming Architecture for next-generation gaming experiences. The inclusion of 0dB Technology, AUTO-EXTREME technology, and a dual BIOS option further enhances its reliability and user experience. Whether you're gaming at 4K resolutions or working on intensive multimedia projects, this graphics card delivers exceptional performance and quality.
Enhanced cooling
The Dual Radeon RX 7800 XT 16GB features an advanced cooling system with Axial-tech Fan Design, Dual Fan Design, and Dual ball Bearing Fans, ensuring superior thermal performance even under intense gaming sessions. -
Immersive gaming experience
Equipped with AMD FidelityFX Super Resolution 2 (FSR) and AMD Noise Suppression, this graphics card delivers a stunningly clear and fluid gaming experience, enhancing visual fidelity without compromising performance. -
Robust build quality
Featuring an aluminum backplate and a stainless-steel mounting bracket, the ASUS Dual Radeon RX 7800 XT 16GB is built to last, providing durability and stability for long-term use.
- ASUS Dual Radeon RX 7800 XT 16GB - OC Edition - graphics card - Radeon RX 7800 XT - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- AMD Radeon RX 7800 XT
- Memory
- 16 GB GDDR6
- Memory Speed
- 19.5 Gbps
- Boost Clock
- 2475 MHz
- Boost Clock (OC)
- 2520 MHz
- Stream Processors
- 3840
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.6
- 4.93 cm x 27.99 cm x 13.39 cm
- Package Type
- Box
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Boost Clock
- 2475 MHz
- Boost Clock (OC)
- 2520 MHz
- Stream Processors
- 3840
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- OpenGL 4.6
- Dual ball Bearing Fans, AUTO-EXTREME technology, Dual Fan Design, Axial-tech Fan Design, 0dB Technology, Dual Bios, aluminium backplate, stainless steel mounting bracket, RDNA 3 Gaming Architecture, AMD Radiance Display Engine, AMD Noise Suppression, AMD FidelityFX Super Resolution 2 (FSR), HDCP
- Size
- 16 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 19.5 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 750 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Software Included
- ASUS GPU Tweak III, Adobe Creative Cloud (1 month membership), AMD Radeon Software Adrenalin Edition, ASUS Quantumcloud
- HDCP 2.3, DisplayPort 2.1
- 4.93 cm
- 27.99 cm
- 13.39 cm
- Package Details
- Box
