ASUS Dual GeForce RTX 4070 SUPER EVO 12GB Graphics Card
Quicklinx: HX1NWS00 Mfr#: DUAL-RTX4070S-12G-EVO
The ASUS Dual GeForce RTX 4070 SUPER EVO 12GB video card is a powerhouse for gamers and creative professionals alike. With 12 GB of GDDR6X memory, a 192-bit bus width, and a memory speed of 21 Gbps, it delivers performance for 4K gaming and demanding applications. The card supports OpenGL 4.6 and comes with advanced features including 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, and NVIDIA DLSS 3, ensuring lifelike visuals and fluid gameplay. It's HDCP 2.3 compliant and supports up to 4 monitors, making it perfect for multi-display setups. The included 16-pin to 2x 8-pin cable adapter and a thank you card add a touch of appreciation for choosing ASUS. Whether you're battling in titles, creating stunning 3D renders, or streaming content, the ASUS Dual GeForce RTX 4070 SUPER EVO 12GB is engineered to meet expectations.
  • Enhanced cooling
    The ASUS Dual GeForce RTX 4070 SUPER EVO 12GB features an advanced 2.5-slot Fan Cooler, Axial-tech Fan Design, and AUTO-EXTREME technology, ensuring your video card remains cool under heavy load for reliable performance and longevity.
  • Superior visuals
    Equipped with NVIDIA GeForce RTX 4070 SUPER graphics processor and 12 GB of GDDR6X SDRAM, this video card delivers stunning visuals, smooth frame rates, and detailed graphics at resolutions up to 7680 x 4320. Experience gaming with 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for real-time ray tracing and AI-enhanced graphics.
  • Next-gen gaming features
    With NVIDIA DLSS 3, NVIDIA Reflex, and support for up to 4 monitors, the ASUS Dual GeForce RTX 4070 SUPER EVO 12GB is designed for a comprehensive gaming experience. Enjoy reduced latency, improved responsiveness, and breathtaking image clarity, making every game more immersive and competitive.
ASUS Dual GeForce RTX 4070 SUPER EVO 12GB - graphics card - GeForce RTX 4070 Super - 12 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
12 GB GDDR6X
Memory Speed
21 Gbps
Core Clock
2475 MHz
Boost Clock (OC)
2505 MHz
CUDA Cores
7168
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
4.96 cm x 22.72 cm x 12.324 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2475 MHz
Boost Clock (OC)
2505 MHz
CUDA Cores
7168
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Dual Fan Design, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Axial-tech Fan Design, NVIDIA DLSS 3, 2.5-slot Fan Cooler, 0dB Technology, Dual ball Bearing Fans, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Dual Bios, AUTO-EXTREME technology, NVIDIA Ada Lovelace GPU technology, stainless steel mounting bracket, vented backplate, anti-bending plate, 144-hour Validation Programme, Optical Flow Accelerator, Resizable BAR, NVIDIA G-Sync ready, HDCP
Size
12 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
192-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
Thank you card, 16-pin to 2x 8-pin cable adapter
Software Included
ASUS GPU Tweak III, ASUS Quantumcloud, Adobe Creative Cloud (1 month membership), NVIDIA GeForce Experience
DisplayPort 1.4a, HDCP 2.3
4.96 cm
22.72 cm
12.324 cm
