ASUS Chromebox 3 features a powerful processor and DDR4 memory for faster, smoother and more energy-efficient performance. It gives you the ability to run your favorite mobile apps with the power of a mini PC.
Extensive connectivity with power-delivery technology
ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables. -
Dual display productivity
ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays. -
Incredibly silent and energy efficient
ASUS Chromebox 3 is ideal for office environments because it operates in remarkable silence, thanks to optimized fan settings that keep noise levels down. And it doesn't get much noisier at full load either. The fan helps lower operating temperatures, so you're guaranteed silent, stable performance. -
Built-in security features
ASUS Chromebox 3 is designed from the ground up with security in mind, so you'll be safe from viruses and malware. There's no need to buy and install additional security software, and certainly no time wasted trying to get in touch with tech support.
- ASUS Chromebox 3 N041U - mini PC - Core i3 7100U 2.4 GHz - 8 GB - SSD 64 GB
- Chromebox - mini PC
- Processor
- 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 64 GB - M.2
- Optical Storage
- No optical drive
- Card Reader
- 3 in 1
- Graphics Controller
- Intel HD Graphics 620
- Networking
- 1GbE, Wi-Fi, Bluetooth 4.2
- OS Provided
- Google Chrome OS
- 14.85 cm x 14.85 cm x 4 cm
- 1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Chromebox
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U
- Clock Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
Hard Drive
- SSD - M.2
- Capacity
- 1 x 64 GB
Optical Storage
- No optical drive
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Wi-Fi, Bluetooth 4.2
- 2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) ¦ 1 x HDMI ¦ 1 x headphones/microphone (1 in front) ¦ 1 x LAN (Gigabit Ethernet) ¦ 1 x DisplayPort/USB-C 3.1 Gen 1 ¦ 3 x USB 3.1 Gen 1
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- UL, VCCI, BSMI, CB, FCC, RCM
- Power adapter
Operating System / Software
- OS Provided
- Google Chrome OS
Sustainability Information
- ENERGY STAR Certified
- 14.85 cm
- 14.85 cm
- 4 cm
- 1 kg
- Sound Emission
- 19.3 dB
