Extensive connectivity with power-delivery technology
ASUS Chromebox 3 can charge a connected phone or accessory, and can also receive power from a supported display or other device, eliminating the need for a separate power adapter for a cleaner workspace uncluttered with cables. -
Dual display productivity
ASUS Chromebox 3 supports dual displays via HDMI and USB Type-C without the need for an additional graphics card, making multitasking a whole lot easier. Spread out your documents, mirror content or extend a single browser across multiple displays. -
Incredibly silent and energy efficient
ASUS Chromebox 3 is ideal for office environments because it operates in remarkable silence, thanks to optimized fan settings that keep noise levels down. And it doesn't get much noisier at full load either. The fan helps lower operating temperatures, so you're guaranteed silent, stable performance. -
Built-in security features
ASUS Chromebox 3 is designed from the ground up with security in mind, so you'll be safe from viruses and malware. There's no need to buy and install additional security software, and certainly no time wasted trying to get in touch with tech support.
- ASUS Chromebox 3 N005U - mini PC - Core i5 8250U - 8 GB - SSD 128 GB
- Chromebox - mini PC
- Processor
- 1 x Intel Core i5 (8th Gen) 8250U (Quad-Core)
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Hard Drive
- SSD 128 GB - M.2
- Optical Storage
- No optical drive
- Card Reader
- 3 in 1
- Graphics Controller
- Intel UHD Graphics 620
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- OS Provided
- Google Chrome OS
- 14.85 cm x 14.85 cm x 4 cm
- 1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Chromebox
- Product Form Factor
- Mini PC
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
Hard Drive
- SSD - M.2
- Capacity
- 1 x 128 GB
Optical Storage
- No optical drive
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- microSD, microSDHC, microSDXC
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- 2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB 3.1 Gen 1
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- UL, VCCI, BSMI, CB, FCC, RCM
- Power adapter
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
- Google Chrome OS
Sustainability Information
- ENERGY STAR Certified
- 14.85 cm
- 14.85 cm
- 4 cm
- 1 kg
- Sound Emission
- 19.3 dB
