Asus Chromebook Flip CB3 Intel Core i3-1215U 8GB 256GB SSD 14"
Quicklinx: HC6VWS00 Mfr#: CB3401FBA-LZ0099
Type: Chromebook
Screen Size: 14in
Processor Model: I3-1215U
Operating System: Google Chrome OS
Installed Memory: 8GB
  • Core i3
  • IEEE 802.11n
33 In Stock
£504.77 ex VAT
£605.72 inc VAT
The 14-inch ASUS Chromebook Flip CB3 offers an exquisite blend of powerful performance and versatility to empower the way you work and play. It features a stylish exterior, the power of up to an Intel Core processor and a fanless design, plus Wi-Fi 6E and long-lasting battery life, so you'll be well-equipped to breeze through everyday tasks from anywhere. Also, a garaged stylus and a 360° ErgoLift hinge spice up entertainment experiences and add versatility. To top it all off, military-grade durability keeps ASUS Chromebook Flip CB3 protected when on the go.
  • 360° of style and ergonomics
    ASUS Chromebook Flip CB3 features an eye-catching new color - AI Blue - which matches perfectly with its incredible style and design. The precision-crafted chassis has a dual-tapered design, converging the body and lid to form a V-shaped edge that facilitates opening the device. For excellent ergonomics, a precision-engineered 360° ErgoLift hinge smoothly adjusts the display at any angle and lifts and tilts the keyboard into the most comfortable typing position.
  • The power to stay productive
    Powered by the 12th Gen Intel Core i5 processor, ASUS Chromebook Flip CB3 delivers performance and responsiveness to empower users with incredible productivity.
  • Seamless visuals for focused workflows
    ASUS Chromebook Flip CB3 delivers seamless visuals for boundless productivity. The four-sided NanoEdge display maximizes screen area and screen-to-body ratio, making viewing experiences more immersive. The 14-inch Full HD panel also offers wide viewing angles and exceptional color reproduction for incredibly vivid, true-to-life imagery.
  • A touch of genius
    The included stylus quickly and automatically charges when garaged - only 15 seconds of charging provides up to 45 minutes of use - keeping it ready for use and providing a safe place to store it. The intuitive movement of the stylus is a quick, precise way to unleash your creativity and productivity: take notes, sketch or jot down those "Aha!" moments whenever innovative ideas strike.
  • Double the cameras, double the inspiration
    ASUS Chromebook Flip CB3 has two cameras: one standard webcam with a privacy shield and a special world-facing camera that provides you with a totally new way to explore your creativity.
  • Military-grade toughness
    With structural reinforcements to boost chassis strength, ASUS Chromebook Flip CB3 is built to provide toughness for on-the-go lifestyles. It also meets next-level and industry-leading US MIL-STD 810H durability standards, which are more rigorous and demanding than ever before. Additionally, the device undergoes stringent in-house testing - including panel-pressure, shock and drop tests - to ensure maximal toughness, so you don't have to worry about everyday knocks and bumps.
  • Ultimate typing experiences
    From its keyboard to its touchpad, typing and cursor control on ASUS Chromebook Flip CB3 is a pleasant experience, thanks to a host of features and improvements that enhance productivity and comfort. ASUS Chromebook Flip CB3 has a full-sized backlit keyboard that offers 1.4 mm key travel for more comfortable typing. The backlit keyboard lets you type effortless in dark environment from twilight café tables to aircraft cabins.
  • Fast, stable connections
    Tested and certified with ASUS Wi-Fi Master for Chrome, ASUS Chromebook Flip CB3 features a Wi-Fi 6E chip that allows you to load online content in the blink of an eye. Connections are made even better by exclusive ASUS technologies that enhance speed, stability and range, so you can enjoy fast, high-quality connections from anywhere!
  • Multiple I/O ports for flexibility
    ASUS Chromebook Flip CB3 provides seamless connectivity for expanding possibilities. Two full-function, reversible USB-C 3.2 Gen 1 ports make it easy to charge, stream media or connect with peripherals, and two USB Type-A ports offer added flexibility. There's also a microSD slot to enable extra storage for maximum convenience and compatibility.
  • Fast, easy charging
    With the amazing long hour battery life on a single charge of ASUS Chromebook Flip CB3, traveling and working without a charger isn't a big deal.
ASUS Chromebook Flip CB3 CB3401FBA-LZ0099 - 14" - Intel Core i3 - 1215U - 8 GB RAM - 256 GB SSD
Chromebook - flip design
Operating System
Chrome OS
Intel Core i3 (12th Gen) - 1215U / 1.2 GHz, up to 4.4 GHz / 10 MB Cache
8 GB LPDDR4X (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
14" touchscreen 1920 x 1200 / WUXGA @ 60 Hz
Graphics
Intel UHD Graphics
Input Device
Stylus
Keyboard Backlight
Integrated Webcam
Bluetooth 5.1, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
3-cell
Security
Titan-C Security Chip
Zinc
31.95 cm x 23.49 cm x 2.09 cm
1.81 kg
Operating System
Google Chrome OS
Processor / Chipset
CPU
Intel Core i3 (12th Gen) 1215U / 1.2 GHz
Max Turbo Speed
4.4 GHz
Number of Cores
6-core
Cache
L3 - 10 MB
RAM
8 GB (provided memory is soldered)
LPDDR4X SDRAM
Storage
Main Storage
256 GB SSD M.2 PCIe 3.0 - NVM Express (NVMe)
Display
14"
Touchscreen
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Colour Gamut
45% NTSC
Glossy, WideView, 170° horizontal and vertical viewing angle, 20 ms response rate (typical), 25 ms response rate (max)
Audio & Video
Graphics Processor
Intel UHD Graphics
Camera
Yes - 720p
Camera Features
Privacy shutter
Sound
Harman/kardon stereo speakers, array microphone
Audio Features
Output: Google Assistant
Input
Keyboard, touchpad, stylus
Keyboard Backlight
Chiclet keyboard
Communications
Wireless
Dual stream (2x2)
3-cell Lithium Ion
63 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
45 Watt, 15 V, 3 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.2 Gen 2 , 2 x USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) , HDMI
Memory Card Reader
Yes (microSD)
Zinc
Case Material
Plastic
Security
MIL-STD-810H tested
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter, USI stylus
1.81 kg
Sustainability Information
TCO Certified
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HC6V 051118
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £443.64
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Chromebook
Screen Size: 14in
Hard Drive Capacity: 256GB
Graphics: Intel UHD Graphics
Brand: Asus
Price Range Ex VAT: £500 - £750
Stock Status: Used Stock
