Asus Chromebook 15.6" Full HD Celeron N3350 8GB 64GB
Quicklinx: GVFQWS00 Mfr#: C523NA-A20440
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
ASUS Chromebook C523 is the simple way to boost your productivity and have more fun on the move - all day and every day. This ultra-portable and lightweight Chromebook is powered by an advanced processor and gives you the freedom of battery life. It also features a NanoEdge design, which gives you a big screen in a compact chassis for easier multitasking and more immersive entertainment. With its speedy performance, robust security and convenient features, it's not only perfect for students - it's ideal for anyone who's always on the go.
  • Strong, stylish and light
    With its aluminum-finished lid and thin profile, ASUS Chromebook C523 has a distinctively premium look and feel. Designed for effortless mobility, it's your take-anywhere companion that's always ready to go wherever your day takes you.
  • Stunning vision
    The stunning NanoEdge display has an ultra-narrow bezel and features a matte anti-glare coating to reduce annoying reflections. The result is a laptop with an impressive screen-to-body ratio that minimizes size while helping you maximize productivity - so you can see and do more, while carrying less.
  • Durable 180° hinge
    With its 180° hinge, ASUS Chromebook C523 can be laid flat to share content easily with friends and colleagues. Its unique, durable hinge design has been subjected to a grueling test to ensure long-term reliability.
  • Powerfully clear sound
    Despite its thin and light design, ASUS Chromebook C523 doesn't compromise on sound quality. With high-quality stereo speakers and extra-large resonant chambers that generate high-fidelity audio, it can deliver surround-sound effects that are as good as much larger laptops, with crisp and powerful sound to give you an immersive experience for both music and video streaming.
  • Work or play, all day
    The power-efficient ASUS Chromebook C523 is designed to last for hours, so you can work or play throughout the day while you're on the move.
  • USB-C for ultimate flexibility
    Two full-function reversible USB-C (Type-C) ports make it easy to charge ASUS Chromebook C523 or connect it to devices and external displays. USB-C provides superfast data-transfer speeds.
  • Extreme typing comfort
    A full-size, ergonomic keyboard with an optimal key travel ensures supreme typing comfort. Typing on a compact device has never been this comfortable.
  • Easy, precise control
    With the super-large touchpad on ASUS Chromebook C523, ASUS gives you more space for smooth control, and multi-touch gestures are more intuitive.
ASUS Chromebook C523NA A20440 - 15.6" - Intel Celeron - N3350 - 8 GB RAM - 64 GB eMMC
Chromebook - 180-degree hinge design
Operating System
Chrome OS
Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
8 GB LPDDR4 (provided memory is soldered)
Storage
64 GB eMMC
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 500
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
2-cell - up to 10 hours
Security
Titan-C Security Chip
Silver
35.8 cm x 24.85 cm x 1.61 cm
1.69 kg
Environmental Standards
ENERGY STAR Qualified
0.398 W/kg (body) , 0.398 W/kg (limb)
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
2 MB
RAM
8 GB (provided memory is soldered)
LPDDR4 SDRAM
Speed
2400 MHz
Storage
Main Storage
64 GB eMMC
Display
15.6"
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
Glossy
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Chiclet keyboard
Communications
Wireless
Dual stream (2x2)
2-cell lithium polymer
38 Wh
Run Time
Up to 10 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
45 Watt, 15 V, 3 A
Connections & Expansion
Interfaces Details
2 x USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB 3.2 Gen 1 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Silver
Case Material
Aluminum, plastic
Security
USB-C power adapter
SAR Value
0.398 W/kg (body), 0.398 W/kg (limb)
1.69 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
