Asus Cerberus V2 Headset Red
Quicklinx: D878WS00 Mfr#: 90YH015R-B1UA00
The ASUS Cerberus gaming headset just got even better. With exclusive ASUS Essence drivers, stainless-steel headband, and wrap-around ear cushions, Cerberus V2 offers improved audio performance with richer, stronger bass, and a tougher, more comfortable design. In addition to gaming, its stylish looks and dual microphones make Cerberus V2 the perfect companion for listening to music on the go.
  • Stronger bass, clearer sound
    Exclusive ASUS Essence drivers bring gaming audio to a whole advanced level, fully immersing you in the game with lifelike sound effects. ASUS engineers reduced the size of the drivers from 60 mm in the original Cerberus to 53 mm in Cerberus V2, enabling the headphones to have larger chambers for richer, more natural sound. Combined with the drivers' wide frequency response that delivers hard-hitting bass and detailed mid- and high-range pitches, Cerberus V2 is not only great for gaming, but for music listening as well.
  • Tough, long-lasting design
    To withstand the rigours of intense gaming, Cerberus V2's headband has been redesigned with a durable, stainless-steel construction. This design is not only stronger, but lighter and thinner, making it more comfortable and well suited for long gaming sessions and listening to music on the go.
  • Better sound insulation
    Cerberus V2 has amazing ear cushions that provide larger coverage area and better sound insulation to keep you more comfortable and immersed in your game.
  • Good for gaming and on-the-go chat
    Cerberus V2 is thoughtfully designed with two microphones: a detachable boom mic that provides clear communication when gaming, and an in-line microphone that is convenient for phone calls and other everyday tasks.
  • Cross-platform compatibility
    Cerberus V2's 4-pole audio/mic combined connector provides compatibility with PC and Mac, gaming consoles, and mobile devices. An included audio/mic splitter also enables Cerberus V2 to be used with dual-port devices, including motherboards and certain laptop models.
ASUS Cerberus V2 - headset - 3.5 mm jack
Headset - wired - 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Game console, portable electronics, computer
Red
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom & on-cable
Microphone Operation Mode
Uni-directional, omni-directional
Controls
Volume, microphone on/mute
ROG Strix G GL531GU; ROG Strix G15; G17; ROG Zephyrus G14; M15; S15; S17; TUF Gaming F17; FX505DT; FX505DV; TUF505DV
Compatibility
Mac, Windows
22.484 cm
19.84 cm
344 g
Red
Headband Material
Stainless steel
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
53 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom & on-cable
Detachable headset microphone
Frequency Response
50 - 10000 Hz
Audio Input Details
Uni-directional - 50 - 10000 Hz , Omni-directional - 50 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
Cable Length
1.2 m
Cable Details
Headset cable - 1.2 m , Audio splitter cable
ASUS ROG Strix G GL531GU WB53 , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Zephyrus G14 GA401II-025T , ASUS ROG Zephyrus M15 GU502LV-HC049T, GU502LW-HN138T , ASUS ROG Zephyrus S15 GX502LWS-HF020T , ASUS ROG Zephyrus S17 GX701LWS-HG052T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT HN571T , ASUS TUF Gaming FX505DV , ASUS TUF505DV HN232T
