Asus C423NA BV0314.0 HD/Celeron N3350/8GB/32G EMMC chrome os
Quicklinx: GBWJWS00 Mfr#: C423NA-BV0377
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
ASUS Chromebook C423 is the simple way to boost your productivity and have more fun on the move - all day and every day. This portable and lightweight Chromebook is powered by an advanced processor, and gives you the freedom of long battery life. It's also the first ASUS Chromebook to feature a NanoEdge design, which gives you a big screen in a compact chassis for easier multitasking and more immersive entertainment. With its speedy performance, robust security and convenient features, it's not only perfect for students - it's ideal for anyone who's always on the go.
  • Strong, stylish and light
    With its aluminum-finished lid, thin profile and low weight, ASUS Chromebook C423 has a distinctively premium look and feel. Designed for effortless mobility, it's your take-anywhere companion that's always ready to go wherever your day takes you.
  • Stunning vision
    The stunning NanoEdge display has an ultra-narrow bezel, and features a matte anti-glare coating to reduce annoying reflections. The result is a laptop with an impressive screen-to-body ratio that minimizes size while helping you maximize productivity - so you can see and do more, while carrying less!
  • Durable 180° hinge
    With its 180° hinge, ASUS Chromebook C423 can be laid flat to share content easily with friends and colleagues. Its unique, durable hinge design has been subjected to a grueling open-and-close test to ensure long-term reliability.
  • Powerfully clear sound
    Despite its thin and light design, ASUS Chromebook C423 doesn't compromise on sound quality. With dual high-quality stereo speakers and extra-large resonant chambers that generate high-fidelity audio, it can deliver surround-sound effects that are as good as much larger laptops, with crisp and powerful sound to give you an immersive experience for both music and video streaming.
  • Breeze through your tasks
    ASUS Chromebook C423 delivers great performance for popular apps, with extraordinary battery life. Combined with the full power of G Suite and other productivity apps, ASUS Chromebook C423 lets you breeze through all your everyday tasks on the go.
  • Work or play, all day
    The power-efficient ASUS Chromebook C423 is designed to last all day long on a single charge, so you can work or play throughout the day while you're on the move.
  • USB-C for ultimate flexibility
    Two full-function reversible USB-C (Type-C) ports make it easy to charge ASUS Chromebook C423 or connect it to devices and external displays. USB-C provides superfast data-transfer speeds. For maximum convenience and compatibility, the ASUS Chromebook C423 also features standard USB 3.1 ports, and there's a microSD slot for adding more storage.
ASUS Chromebook C423NA BV0377 - 14" - Intel Celeron - N3350 - 8 GB RAM - 32 GB eMMC
Chromebook - 180-degree hinge design
Operating System
Chrome OS
Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
8 GB LPDDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Input Device
Mouse
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
2-cell
Security
Google Security Chip H1
Silver
32.2 cm x 22.8 cm x 1.61 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
0.377 W/kg (body) , 0.377 W/kg (limb)
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
8 GB (provided memory is soldered)
LPDDR4 SDRAM
Storage
Main Storage
32 GB eMMC
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Speaker, microphone
Input
Mouse, keyboard, touchpad
Chiclet keyboard
Communications
Wireless
2-cell Lithium Ion
38 Wh
AC Adapter
Input
Output
45 Watt, 15 V, 3 A
Connections & Expansion
Interfaces Details
2 x USB 3.2 Gen 1 , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Silver
Security
Optical mouse, USB-C power adapter
UL, C-Tick, BSMI, CB, JATE, FCC, A-Tick
SAR Value
0.377 W/kg (body), 0.377 W/kg (limb)
1.2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
