Asus C3 Webcam
Asus C3 Webcam
Quicklinx: GRYMWS00 Mfr#: 90YH0340-B2UA00
Enjoy sharper, smoother video streaming and crystal-clear audio with ASUS Webcam. Delivering crisp and detailed FHD (1920 x 1080) video in a widescreen format, ASUS Webcam can be connected via USB and placed anywhere on your desk or on top of your monitor. A 360° rotation mechanism ensures flexibility for any camera angle, and a built-in beamforming microphone array ensures loud and clear audio.
  • Sharp and smooth FHD streaming
    Enjoy high-resolution 1080p video calls and streams at a buttery-smooth 30 frames per second.
  • Wide field of view
    The wide angle lens captures more, making ASUS Webcam perfect for conferences, telecommuting, or chats with two or more parties sitting side-by-side.
  • Beamforming mic for clearer audio
    ASUS Webcam C3 features two built-in microphones with beamforming technology to filter out ambient noise, such as fan whir, keyboard clicks, in-game sounds and voices other than your own - so you'll always come in loud and clear.
  • Adjustable clip for different devices
    The 90° tilt-adjustable clip fits a variety of laptop screens and desktop monitors, and it rotates 360° for more flexible placement options.
  • Broad compatibility
    ASUS Webcam C3 is compatible with PC, Mac, and Chrome OS. It's the ideal solution for video conferencing, video calls or eLearning.
ASUS C3 - webcam
Webcam
Audio
Yes: beam-forming dual microphones
8 cm x 4.8 cm x 5 cm
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
Tilting Range (degree)
90
USB
USB cable - 2 m
Tilt adjustment, manual 360° rotation
Webcam
Audio Support
Wired
8 cm
4.8 cm
5 cm
Camera
Max Digital Video Resolution
1920 x 1080
Digital Video Capture Resolution
1080p
Frame Rate (max)
Tilting
Range (degree)
90
Computer Interface
USB
USB cable - 2 m
