The ASUS Chromebook C213 is the ideal education computer for every school IT manager, student, and teacher. With its classroom ruggedness, the ASUS Chromebook C213 is developed to meet the daily rigors and intense usage by students both inside and outside of the classroom. Beyond its rugged construction, the ASUS Chromebook C213 is also designed for easy maintenance to minimize downtime. The result is a Chromebook, which is designed for maximum usage, creating more learning opportunities for students.
Robust, reinforced rubber, wrapped protective guard
All exterior edges and corners of the C213 Chromebook are protected, using reinforced nano-molding technology, which ensures critical components are secured. -
Spill-proof keyboard a must for the classroom
A classroom of students presents many possible scenarios for accidents. Very common is the accidental spilling of liquid on the notebook and keyboard. That's why the C213 Chromebook keyboard is spill-proof and can repel liquid, giving you the additional peace of mind. -
Easy-grip design for better holding traction
Imagine a typical school day and it will be easy to understand the potential hazards in the accidental dropping of the notebook. From the loose of grip, when carrying the notebook, from passing the notebook from one student to another or even an accidental push off from the table are very real scenarios. That's why the C213 Chromebook is designed with 2 special grips, which are strategically located to minimize these hazards. -
180-degree hinge allows a fully open Chromebook
Ideal for easy viewing, especially for group study or collaboration. -
Larger character-printed keys
Provides superior legibility for easier typing. -
Anti-glare display
Easy to view even in sunlight and less strenuous on the eyes. -
Long hours of battery life
A notebook's battery life, which can last the full school day and without having to sacrifice on the brightness of the display, are crucial for students. Not forgetting the field trips or projects outside of the classroom environment, where there is no available power source, makes the battery life even more critical. There is no worries with the C213 Chromebook, as it has a long battery life with normal brightness to last the full school day.
- ASUS Chromebook Flip C213NA BW0034 - 11.6" - Intel Celeron - N3350 - 4 GB RAM - 32 GB eMMC
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR4 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 500
- Input Device
- Stylus
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 4-cell
- Grey, dark grey
- 30.7 cm x 19.9 cm x 2.06 cm
- 1.3 kg
- Limited warranty - 3 years - on-site
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR4 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 50% NTSC
- Glare, WideView
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 5 Megapixel (rear), 1 Megapixel (front)
- Image Sensor Type
- CMOS
- Video Resolutions
- 720p
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad, stylus
Communications
- Wireless
- Technology
- 4-cell Lithium Ion
- Capacity
- 46 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , 2 x USB-C 3.1 Gen 1 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Grey, dark grey
- ASUS USB Charger+
- Included Accessories
- Stylus, power adapter
- 1.3 kg
Sustainability Information
- TCO Certified
